Question about Dayton Audio Dayton 6K138 CapacitorStart
I need a wiring diagram for a farm duty 6k714k
I need a 115V wiring diagram for a dayton farm duty 6k714k
    Brigadier General:
  • 4,088 Answers
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Posted on Jun 23, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Pump will not pump or turn
If you can rotate the shaft replace the capacitor, if not replace the pump. This is a general rule I follow. I do not know your pump but this would be a starting point.
Apr 16, 2014 | Dayton Wire Wheels Dayton 5PXG7 Pool Pump...
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
Dayton model 6k754m 1 hp motor compressor duty dual voltage turns ccw and needs to turn cw leed t2 &t3 need connection diagram.
Grainger parts can send you the diagram if it is missing or illedgible from the motor nameplate. Contact them at http://www.grainger.com/Grainger/RP_cont.jsp or 1-800-323-0620.
John
Aug 23, 2011 | Dayton Dryers
Trying to wire for 115v
You probably know that you have a pricey and complex motor there. I can be wired for either 110 or 220 volts and it even has a reverse. I am guessing that new it would cost around $700.
That being said, I want you to consider having it wired by a pro since no wiring diagram is available to you.
If you don't want to hire a pro, then i would contact the Grainger folks and see if they can obtain the wiring diagrams for you. good luck with it.
Mar 29, 2009 | Dayton 1hp 1725RPM 56C Frame 90 Volt Dc...
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton Audio Dayton 6K138 CapacitorStart Logo
826 people viewed this question
Top Dayton Audio Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dayton Audio Air Tool and Compressor Expert? Answer questions, earn points and help others
