Question about Canon imageRUNNER 5000 Copier
IRC5185i Stopped working. Shows Error code
Canon IR C5185i Stopped working. Shows Error code E000009-0500. What does that mean? Is there a user fix?
  • Anonymous Mar 25, 2014
    how can reset my canon irc5185i display not working
  • 149 Answers
I looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Posted on Jun 10, 2010
How to clean error code E000732-8888 for canon IR C5185
E732 Reader communication error.
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Mar 11, 2015 | Canon irc5185i
What does error code E00423-002 mean?
Are you write correct error code?
Canon irc5185i error codes have format Exxx-yyyy, not Exxxxx-xxx!
Sep 07, 2014 | Canon irc5185i
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
Canon iRC5185i with the erro code E000007-0201 . i need the solution to clear this erro
Manual:
E007-0201 Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
I can't understand what it means.
Oct 25, 2013 | Canon irc5185i
HOW CAN I SOLVE ERROR CODE E000007 0001 IRC 5185
Fixing belt home position detection error.
Replace Home Position sensor - 0,001%
Replace the Fixing unit - 105,9%
Feb 11, 2013 | Canon irc5185i
How to clear error 000732-0001 i rc5185i
0001 DDI-S communication error
Check the connections between the reader controller PCB and main controller PCB. Check the power supply of the reader.
Jan 29, 2013 | Canon irc5185i
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
713 people viewed this question
old marine
old marine
