Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
Replaced a light switch for a ceiling fan. Switch
Replaced a light switch for a ceiling fan. Switch has 2 black wires. Do both go with the other black wires or does one go with the white wires?
When Took the cover off, 1 was loose. Swich was broken so had to replace. Put both black together with the other black ones,and no light. Suspect the loose one may have been connected to the white wires?
  • 8,404 Answers
On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
All white wires normally go together.
Posted on Jun 05, 2010
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
House wireing red,white,black. how do i hook up a cealingfan with light kit pull chain on.
For starters, look at the wall switch. Are there two switches? If so, connect the black wire from the ceiling box to the black wire from the fan. Connect the red wire from the ceiling box to the blue wire from the fan. Connect white to white. At the fan, usually the black wire goes to the fan and the blue wire goes the the light.
If there is only one wall switch, you may or may not want to install a double switch so the fan and light can be controlled separately. If there is only one wall switch, most people just connect the wire connected to that switch (usually the black) to both the black and blue from the fan, not using the red at all. In that scenario both the light and the fan are switch at the fan as needed after the wall switch is operated.
Installing the extra red wire is not usual practice, someone actually was planning for future use and convenience.
Apr 16, 2011 | Solar 2-wire Pull Chain Light Switch For...
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
Fix new pull switch to turn on light on ceiling fan
either one all it does is complete the circuit. only one wire is broken to open the circuit when you cut it on and off you just open and close the circuit with one wire.
Jul 29, 2009 | Solar 2-wire Pull Chain Light Switch For...
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
182 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
