Hp dvd1170 external is not recognized by computer even after new windows xp installed on new hard drive, exactly as it was on old drive, what can be my problem?
  • 2 more comments
  • Angelo Valentino Montalbano
    Does it have error code 39?
  • Zee  Oueued
    Zee Oueued Jun 05, 2010
    No code, whether its plugged in USB prior to turning on computer or while running, same thing happens, immediately flag pops up saying USB device malfunctioned and computer is unable to recognize it, then its installed as a unknown device.
  • Zee  Oueued
  • Zee  Oueued
    Zee Oueued Jun 08, 2010
    I solved it, my drivers were incorrectly mounted, and after examining the USB enhanced controller drive, I discovered a number of issues. Certainly explains the problems I was experiencing on my computer besides the external multi dive DVDRAM not being recognized. All of which is due to a new install of windows XP Pro which is not the original, OME was XP Media Edition of which I never used the Media Edition part so while doing a custom install the some of the drivers were improperly installed. So I generated every driver Toshiba installed, including all windows drivers combined. All of them being the most recent available. Thanks to all who contemplated answering my unrecognizable issue and hopefully my solution can help others who might have problems arising from a custom install of an operating system.
    Z Queued
JLPicard
  • 14 Answers
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
Posted on Nov 17, 2007
SOURCE: External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
Posted on Jun 08, 2008
puku_07
  • 60 Answers
SOURCE: my external hard drive does not work on windows xp
reintall xp
and try again
Posted on Aug 30, 2009
chanddra2009
  • 615 Answers
SOURCE: External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Posted on Sep 17, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
May 23, 2012 | HP Omni Computers & Internet
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
My old computer does not recognize my new 250gb wd passport I get an error that my Z drive is not logged on
Are you sure your 'old' computer has USB 2.0 support and not only USB 1.1?
You can try accessing the BIOS of the computer and see if you can change the USB version there.
Once it is recognized, Windows (XP?) should recognize it and install the drivers. If you are running an older OS, you probably need to install drivers for it first. But those would come with the drive (on a CD maybe).
Also check out:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jules
Feb 26, 2009 | Western Digital Passport WDXML800UE...
USB Problem
hmmm external hard drive should work without any problem as windows xp allready have inbuilt drivers for mass-storage.
try to Uninstall the USB driver, goto Device manager and Uninstall USB, then reboot to clean system registry and install USB driver from Windows XP setup disck. and try the external-hard drive, xp should recognize your external-hard drive. If not then install driver for your drive if you have and try. for camera and ipos u need to install drivers and supporting softwares from your manufacturers.
thanks
Iqbal
Mar 31, 2008 | HP Compaq Presario R4000 Notebook
WD1000VE external hard drive not recognized
If possible check it out on another computer.
This will then establish one or the other which is misbehaving.
Then come back
Feb 11, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Computers & Internet Logo
613 people viewed this question
David Payne
David Payne
