Question about Whirlpool Duet GHW9150P Front Load Washer
F20 error - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,382 Answers
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Thank you
Posted on Jun 05, 2010
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to fix F20 error code whirlpool duet
How to fix F20 error code whirlpool duet YouTube
https://www.youtube.com/results?search_query=How+to+fix+F20+error+code+whirlpool+duet
Sep 04, 2014 | Whirlpool Washing Machines
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
Navman f20 wont turn on says F20 ERROR UNABLE TO DETECT INTERNAL MEMORY
Not much to do here I'm afraid. a repair is needed. If your device is not under warranty anymore, you can get in touch with Navman / Mio, they have a trade in offer towards a new Mio device
Feb 22, 2011 | Navman F20 GPS Receiver
I have a error code washer mayta f20
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Jul 14, 2008 | Navman F20 GPS Receiver
Whirlpool Duet GHW9150P Front Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
