Question about Whirlpool Duet GHW9150P Front Load Washer
What cause the door seal to rip on maytag 9700
  • 24 Answers
Lots of things can cause a door seal to rip. The most common is an object in the washer that doesn't belong there, such as a hairpin or a variety of other things. The door seal can also rip on it's own by being dry and grabbing on the glass when you shut the door.
Posted on Jun 05, 2010
Why is maytag front load washing machine is leaking at the bottom of the door
Either the door is out of adjustment or the bellows (the rubber large seal on the front of the machine) has a rip or hole in it . This can happen if you fail to remove all items from clothing before washing. Carefully inspect the bellows for holes or foreign objects remove any objects from the machine and replace the bellows if necessary
Aug 05, 2014 | Maytag Washing Machines
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
Feb 19, 2014 | Maytag Washing Machines
I have a maytag side by side refrigerator and water is colectiong on the top shelf of the fridge side at the side by the freezer. what could be causing this?
That sounds as if the door gasket isn't fully sealing and warm air is entering and condesating resulting in the water ya see on the shelf. Check and see espicially in the corners if the gasket seems to ripped or curled up instead of being flat and flush to the outer edge of the door rim.
GENE
Oct 06, 2011 | Maytag MSD2454G Side by Side Refrigerator
Seal is ripped
Yes, the door seal (bellow) can be purchased and replaced. The following link explains step-by-step how to change the door bellow on a Maytag Epic front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The firsat three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful. NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Apr 30, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Whirlpool Duet GHW9150P Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
