Question about AMS Lutron S2-LFSQ Skylark Dual Slide-to-Off Fan Speed Control and Dimmer 2 in
II have a switch and dimmer and the three wires from fan and light, no instructions how install it.
  • Rich Jun 05, 2010
    Please describe all the wires in the wall box .. from the house, the fan , and the switch.. Thanks .. Rich
    Novelist:
  • 145 Answers
You will have power coming in through a black wire and white wire on the cable set that does not go out to your fan. The black will connect to your switch to power it. Then there will be two other terminals on your switch one for your fan and one for your light. The red and black that go out to your fan and light are connected to these two terminals. The whites get connected together. If you mix the red and black up and the switches are controlling the the wrong things, simply switch the black and red wires. (Note: If by three wires to your fan you meant black, white and bare copper this dual switch cannot be used, as bare copper is simply a ground wire and cannot be used as a constant electrical conductor.)
Posted on Jun 05, 2010
I have s2-lfsqh-wh 300w 1.5a can this be wired as a 3 way if so how
I doubt it. They are designed for a 3 wire cable going to a ceiling fan with 2 loads. They likely would not design a special 2 in one switch if one side is a 3 way. You will have to have 2 switches and a double box to do the same job.
Feb 24, 2013 | Lutron Dimmers S2LFSQ Dual 1.5A Quiet Fan...
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
My cooper 9534ds just melted and smoked inside my wall.
IIs this a 3 or 4 wire dimmer switch and red is feeding the fan with power? off hand It sounds like a failier inside the dimmer. if there was a short inside the fan it should have smoked at the fan or tripped the breaker. sounds like a hot spot in the dimmer.
Apr 26, 2009 | Cooper Industries Cooper Wiring 9534DS...
Want to install Fan and light control from one switch.
'define control'
anyway, that all the lights work together makes it simpler
most fanlights, updated by homeowners replace a lamp only unit, with on/off provided at the switch, and cable pulls on the unit to change speed direction of the fan
my favorite is paired dimmer switches, giving control separately of light and fan speed, fan direction still changes on the pull switch, requires 3 wires in the switch box, (power and 2 switched lines), to the lamp connector and fan motor connector, any sparky can pull the extra line with fishtape along the existing cable run. easy peasey.
Really good electricians pull three wire to light circuits, when the house is built or reno-ed. but you know how oftern that is gonna happen, 3 wire costs 3c more per foot, if there is 3 wire in the switch box -your home and hosed
or just for speed/dimmer control a dimmer switch can replace the existing single switch. but you still have to pull the cords to start the fans
its easy, with the caveat that you may kill yourself, or someone else, or burn the house down, if you dont do it right
Sep 26, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
AMS Lutron S2-LFSQ Skylark Dual Slide-to-Off Fan Speed Control and Dimmer 2 in Logo
193 people viewed this question
Top AMS Electrical Supplies Experts
ashburton
Ottoniel
Mike
Are you an AMS Electrical Supply Expert? Answer questions, earn points and help others
