Question about GE Tritonr XL GSD6260JCC Dishwasher
Top spray arms dont work.
The spray arm under the top rack doesnt seem to spray or at least its not spinning and the one on the ceiling of machine doesnt either. so our glasses come out with dried gritty stuff on them. Is it the pump or a clog or what?
  • 1,543 Answers
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Posted on Jun 05, 2010
  • warhog53 Sep 05, 2010
    The lower spray arm can be cleaned. just take it out and go out to your backyard, put the water hose at full blast. 1st reverse clean each spray hole with a back flush and then clean out with hose on the larger intake hole.. save your self $200 and make sure you do the other 2 spray arms in the same way. Oh yeah check middle arm connection fitting to make sure the rubber washer is not missing for the connection when top tray is in the inside postion.. if not the pressure will not be enough, so the top and middle spray arms will not work very well. I am just a financial planner and fix it myself, after 4 visits from the GE repair man and he did not figure it out. This is a 2 hour job with a helper, after you get it out on your floor and have plently of old towels. Cut off the power and hot water First..... God bless...
I found a piece of soft plastic maybe off a jar in my lower spray arm, maybe there is something blocking the hole...I am having the same issue and am trying to figure out how to remove the top sprayer and look inside. Just a guess, but all I can think of for now.
Posted on Jun 21, 2010
Top water outlet doesn't spin
Not sure of the vintage of your Maytag dishwasher, but this may work for yours.
1. Remove the upper rack by releasing the stop clips on the ends of the rack rail; push the ends of the clips towards center of machine - this may require the help of a small screwdriver.
2. The upper spray arm assembly is mounted to the ceiling of the wash chamber by large (2" diameter) fluted nut that butts right against the ceiling sheet metal. Simply remove that nut by hand, and the whole assembly will come out.
3. Looking into the top of center feed hole, you'll see 4 plastic clip ends holding the 3 pieces together. Use a 1/4# socket or nutdriver to press all 4 clips inward until they come free.
4. The spray arm halves are welded together, so you'll have to clean out any clogs using a pointy tool and some water flushing.
5. Reassembly is the reverse order.
- Mike
Apr 17, 2014 | Maytag Dishwashers
Kenmore Dishwasher #665.16919001dishes on top rack are not getting clean.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 31, 2011 | Dishwashers
The top rack dishes are not being cleaned properly. It seems that the water is not makeing it way throught the feed arm, hence not being feeding the spray arm.
Hi
Jan 27, 2011 | Dishwashers
Dish washer not cleaning dishes in top rack
Hi
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Dishes on upper rack are not being cleaned. Seems like upper sprayer is not working properly.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Daniel
Jan 01, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Top spray arm on dishwasher doesnt move .
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<BR>When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...<BR><BR>Dishwasher Spray Arms not Spinning<BR><BR><A href="http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning" target=_blank><FONT color=#800080>http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning</FONT></A><BR><BR>heatman101 <BR style="mso-special-character: line-break" clear=all><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
Aug 27, 2010 | Frigidaire Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Middle spray arm not spraying
unlikely that 2 dishwashers would have the same fault but is of course possible
could it be to do with how you are loading? quite common is for a knife or similiar to stick down thro the rack and jam the arm
Nov 19, 2008 | Dishwashers
Top rack not cleaning and spray arm possibly not moving
Hello--our Kenmore Elite has been showing exactly the same symptoms.  Since it's under warranty I had a technician take a look at it, in fact he just finished putting it back together: problem was accumulated food and junk around the inlet filter to the pipe that leads to the upper racks.  You can only get to this area by removing the lower spray arm, filter assembly, etc. until you are looking at the sump/chopper area.  Any clogging should be self evident at that point.
This would be an easy repair for anyone with a few tools and the willingness to get into it.  Seems to be working very well.  We will be rinsing more thoroughly in the future...
Feb 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
GE Tritonr XL GSD6260JCC Dishwasher Logo
579 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
