Question about Whirlpool Duet GHW9150P Front Load Washer
Duet front load washer door locked & will not cont wash cycle
Our front load Duet Whirlpool washing machine (it is about 3 years old & we do not have a warrenty) has been on the blink for two days. We have unplugged it several times & plugged it back in (thinking this would reset itself).
We have pushed various buttons, to no avail...it is still STUCK on the Quick Wash (28 minutes shows on the digital panel, still). It actually went thru one wash cycle, BUT the ycle did otcomplete itself, because it stopped @ oe min an went no further. when w unplugged it the first time, we thought it would reset itself, insted it wnt back to displaying 28min on the wash cycle, as if it were starting over----BUT it did not wash...made no sounds...so our clothes are stuck in Duet Washing Machine Land & we still cannot open the door (which has locked itself tightly).
We don't know what to do from here....BUT it sounds like this would be quite expensive to fix, since it appears to do with a mechanized system, of sorts. We have had a little trouble like this before in the past a couple of times...BUT we left the machine alone for a couple of hours...and it always worked itself out. BUT now, this has been two days, and the machine is doing nothing more for us, except to continue with its locked door antics, as well as displaying the 28 min wash cycle on its digital panel.
Appreciate and assistance/advice you can relay on this matter.
  • 1,531 Answers
You can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Posted on Jun 05, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Try door after 2 minutes. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: my door lock how rto unlock it...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front load washer door won't open Sh message in window
Switch on washer. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
Feb 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool control locked
Power shd be on. Press and hold "end of cycle" button for 3 seconds. Always wait for 2 minutes after the wash is over for the machine to release the door lock; an inbuilt safety device. Never force washer doors, you'll have probs.
Check out your filter too.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
