Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Stand by light blinking - Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Sony tv will not turn on stand by timer light blinking
Try as suggested to count the blinks to see if it is an error code or not. blinks will be in a sequence with a pause and blink the same number of times over and over.
Apr 29, 2012 | Televison & Video
KV32XBR450 no picture and blinking stand By light
Typically, 4 blinks mean "Vertical Deflection Stopped." Chances are that you have a problem on the D board.
Nov 19, 2009 | Sony Televison & Video
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
Aug 22, 2009 | Televison & Video
Sony kp tv stand by light keeps blinking and no picture
The standby light LED BLINK is in specific numbers, please count that how many time LED BLINKS in specific time and in specific numbers like 1 time 2 time 3 times etc, every blink has its area of fault which processing IC detects, Therefore please count and let me know the number of blinking stand by light and then i can tell you the area of fault and its solution.
Hope you will understand my sayings, if need more clarification write in comments.
thanks for using fixya.
Jul 25, 2009 | Televison & Video
Stand by light blinking orange, tv won't come on
stand by light blinking orange and the TV won't come on
Aug 31, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Nov 06, 2007 | Sony FD Trinitron KV-32HV600 32" TV
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
1,595 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
