Question about Dishwashers
I have GE Profile Model # PDW9280J00SS. The power button keeps turning on and off on its own. Is there a reset or what part might need replacing. Thanks, Chris
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the power is getting to the dishwasher as it’ll turn on and then after sometime turns off. Also everything else seems to be working fine, please click on this link to buy the control board. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 13, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE PDW9280J00SS not draining. I have read other posts that say this is a "water level sensor problem" but that doesnt make sense since it FILLS to the proper level. After cleaning cycle, then it...
    GE dishwashers use either a drain solenoid or a separate drain pump assembly. Sounds like your drain pump isn't getting power to it until you start other cycles, which sounds like control board issues.
    Sep 25, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
    I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
    http://www.geappliances.com/search/fast/infobase/10000380.htm
    According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
    Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
    GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
    Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
    Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
    No water imput. ge profile dishwasher. PDW9280J00SS. TRIED HITTING THE FLOAT COVER.
    Here is a tip that will help you to find out why water will not come into the dishwasher...
    Dishwasher Trouble No Water entering Dishwasher
    heatman101
    Sep 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
    My dishwasher has no power and am hearing A constant highpitched noise
    i do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
    Jul 09, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
    GE Profile PK916, Convc. elements stays on high
    he is right in what he says the heating element is feed from the main control board
    Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    Buttons on Control Panel not working for my GE Profile Gas Range
    Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
    Thanks
    Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
    Dishwashers Logo
    21 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
