Question about GE Washing Machines
Brown oil is leaking from the bottom of the washer
  • 1,543 Answers
The only place oil can come from is the transmission. If you do not have a big leak, it may run a long time (read: maybe a year or more) before low oil level in the transmission causes major appliance damage, but it's time to start looking for a new washer. Many washers these days do not even use an oil filled transmission. Current GE machines do not, and the Whirlpool models comming soon don't either. If you can afford it, the front loading LG washers (which are direct drive, thus no transmission or clutch, and have a 10 year motor warranty) are the best, in my opinion.
Posted on Jun 05, 2010
The water turns brown. I have checked the hoses and detect no coloring.
You may have a tub seal leaking from transmission. Check out YouTube under washer leaking oil. You may see what the problem.
Apr 17, 2014 | Kenmore 22422 Top Load Washer
Locate AC drain line
ac drain pipes are on the passenger side front floor area (just about where your feet go) under car when cars heater core gets a hole in it lots of times antifreeze will leak inside car on floor try to get a small sample of fluid thats leaking out with a tissue or something (white In color) see what color fluid is ,see if fluid is slippery like oil or not (rub it between fingers)
Antifreeze= orange or green in color
Transmission oil = red or brown
motor oil = brown to black
washer fluid = Blue or drk orange
ac condesate= clear water (cold)
Nov 08, 2013 | 2001 Ford Crown Victoria
I have a 1987 Vette that has never dripped anything onto the driveway, until last night. It is really leaking good all of a sudden. Where should I look first.
First you need to identify what's leaking? What color is fluid? Green, Red, Brown? and where under car is fluid leaking from center, front rt, etc... Another option is check ALL fluid levels - coolant, oil, power steering, transmission.
Mar 05, 2011 | 1987 Chevrolet Corvette
Brown streaks on laundry. possible loose drum?
It may be correct. This may also be caused by oil leaking from the washer machine. Perhaps the heat is burning the clothes leaving the streaks.
The common cause of this issue are oil leaks.
Dec 27, 2010 | Frigidaire FGQ332ES Gas Dryer
My Fisher and Paykel 5.0 is leaking brown stuff out the bottom and on to the floor, possibly oil. Where might it be coming from.
no oil in this machine , must rust with water , is it noisy on spin if it is get rid of it , will need a new outer bowl
Jan 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Oil leak at top of pump
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Sep 07, 2009 | Northstar Garden
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Oil ring left in tub and on agitator
If its oil your transmission is leaking oil. Time for a new washer.
Mar 21, 2009 | GE WJSR2070B Top Load Washer
Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
239 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
