Question about Maytag 24 in. MDB8951A Free-Standing Dishwasher
Diswasher May tag
Have-you e recall for my machine this is:
diswasher May tag the number : PDBL 390 AWW about 2006
Excuse-moi for my english, I speak french only,
Donnez-moi une solution pour mazda bt50 et puis il va demarrer le moteur serra le pont que dois- je faire pour ne pas tremble plus
Sorry but the UK stopped talking french in the 14th century at court so everyone had to speak that horrid anglo saxon language called english .So please re-write in a sub human languagecalled english please for a answer
Feb 22, 2013 | Mazda BT50 Cars & Trucks
Kiddieland Singing Activity Workshop started speaking french how do i turn it back to english
Did you work it out? My one has done the same and I can't change it back either
Jan 08, 2013 | Audio Players & Recorders
MY UNIT SPEAKS FRENCH HOW DO I CHANGE TO ENGLISH
speaks french? your unit is speaking to you? im confused. anyway if this helps. this is what your gonna try to do. go to settings "param?tres" and go to language wich will be "la langue" and click on english hahahaha if this dosent work let me know. glad i could help :)
May 12, 2011 | Cell Phones
I speak french,do you speak french?
No, but I speak Hebrew, English and Spanish.
You can find people who speak/study French here!
Regards,
Pelu.
Mar 05, 2011 | Keurig Elite B40 Coffee Maker
I live in Switzerland and have a new Electrolux EB SL6 built in oven. How can I get a user's manual in English?
Unfortunately, you can't as your model has never been intended for English-speaking countries. As far as I recall, it's only available in French, Italian, German and some Eastern European languages.
You will either need to ask someone locally to translate the key sections into English for you, or if you use the FireFox web browser you can add the excellent FoxLingo plug-in which provides translations from a number of sources. All of the software and the translations are free.
Aug 15, 2010 | Microwave Ovens
Vacuum Solenoid control Valve on differentiel front...how test for know them defect or no defect? excuse my english..I speak french
To test start the car and pull off the pipe from the blue valve going to the 4wd shifter on the front axle - it should be sucking in air . now push the dash button for 4wd and pull off the pipe from the grey valve its should be sucking air now and the blue one will not .
Let us know the results as there are more tests to do .
Feb 08, 2010 | 2001 Isuzu Trooper
KEYBOARD PROPLEM
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Chris
Model info for your product can be found at www.hp.com click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
Apr 11, 2009 | HP Computers & Internet
I dont capable the connect my printer. Excuse my english, I dont speak english but I try
pls specify your printer model number
also change your cable which u connect printer and computer.
then donw laod your printer model driver from following link
http://www.driverslab.com/drivers/Printer/Lexmark/1000_Color_Jetprinter_1_0-Windows_2000_XP/3109.html
Sep 30, 2008 | Lexmark Office Equipment & Supplies
Brake light
monsieur landry quand tu change de park aux drive ta lumiere de frein allume confirme moi sa et tu peut verifier tes fuses de montreal pierre
Jun 19, 2008 | 2006 Chevrolet Malibu Maxx
Reference Manual
The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Maytag 24 in. MDB8951A Free-Standing Dishwasher Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
