Question about GE Dishwashers
I have a GE Profile Dishwasher Model # PDW9280J00SS. The power button is turning on and off all by itself? What part needs replacing or is there a reset fuction I should try? Or something else? Thanks for your help. Chris
  • carothers4 Jun 05, 2010
    Jun 05, 2010 - Thanks for your suggestion. Let me give you more details. The outlet is fine. The connection is fine. The touch panel on the dishwasher start button turns on and off while the other buttons stay lit. Also, I have to keep the door open otherwise the dishwasher will start on its own and run through all the cycles over and over.... Hope this helps.
    The dishwasher will start, run through all cycles and stop. Then it will beep and start again.maybe five minutes later or one minute later. if i open the door so it doesn't start running through all the cycles, the start button light turns on and off by itself and beep at the same time that the start button lights up. the beep is typicall when pushing the buttons to start or stop or choose any other cycle button. Thanks
  • GE Master
  • 19,396 Answers
Hi Chris.
Reset is done disconnecting power for about ten minutes (disconnect power cord or trip circuit breaker). This will drain power from internal circuit resetting the control assembly.
The two common resons for dishwasher turning on and off are faulty motor or faulty control board. A wiring problem can also turn machine on and off.
The control board is the last part to replace unless evidently faulty (eg. burnt component, or bulged capacitor etc.).
The test is done jumping and energizing pump motor, ensuring that wiring has continuity, and finally reading voltages from control board to motor with the aid of a diagnostic light or a voltmeter (easier than using a multimeter).
The door latch can also affect the cycle, and must be tested first. The latch is tested by jumping the door switch contacts to bypass the switch.
For safety reasons some of testing procedures described are only suitable for a trained technician.
If you want to arrange repair or verify warranty status, call the GE number listed on the owners manual.
If you want to purchase parts and get diagrams showing how to identify and access parts click here.
Regards.
Ginko
Posted on Jun 05, 2010
  • GE Master
  • 12,061 Answers
Hi Chris, OK, i have found you your service and repair manual, below. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Inside this manual, are all the troubleshooting steps that you will need to follow, to isolate and repair.
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
Above is a DIY website that is very handy helping with the troubleshooting steps. http://gzunino.spaces.live.com/blog/cns!57EA3FC37E8CD48F!879.entry?sa=417851171
Above is a Profile, step[ by step repair how to with pictures, this should be of great assistance.
    Brigadier General:
  • 3,513 Answers
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
GE PDW9280J00SS not draining. I have read other posts that say this is a "water level sensor problem" but that doesnt make sense since it FILLS to the proper level. After cleaning cycle, then it...
GE dishwashers use either a drain solenoid or a separate drain pump assembly. Sounds like your drain pump isn't getting power to it until you start other cycles, which sounds like control board issues.
Sep 25, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
No water imput. ge profile dishwasher. PDW9280J00SS. TRIED HITTING THE FLOAT COVER.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher has no power and am hearing A constant highpitched noise
i do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
Jul 09, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My ge profile model # gsd5132f02ww is not draining the water.what to do?
Max Power :Most likely You need replace MOTOR/PUMP ASSEMBLY GE DISHWASHER on the dishwasher as it sold asone piece.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
GE Profile Built In Dishwsher won't start when you push the start
I turned off the power to the dishwasher for 10 minutes as recommended by a serviceman via the phone and then turned it back on and it reset itself and worked fine.....
Dec 26, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
279 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
