Question about Microwave Ovens
Panasonic Model NN-T994SF runs for approximately 30 seconds and stops. The unit still has power to the front panel and can be restarted (for an additional approximate 30 second interval before it stops again) and does not appear to be cooking at all.
  • 2 more comments
  • Jdubya Apr 09, 2008
    Been there, done that....this symptom doesn't appear to be my problem in this case.
    I have 120V AC going into the PC board and 9.3 V AC coming out of the power supply going to the Magnetron unit when I simulate and initiate a cooking cycle on the front panel. I was hoping you folks might be able to provide the output of the PC board to the Magnetron unit or email a suitable schematic with outputs of the components at the test points within the PC board. This would allow me to 'shoot the bug' down to the component level and save me some time and money.
  • Jdubya Apr 10, 2008
    Yes, very informative WEB pages! After performing the Magnetron test I found that I have a shorted Magnetron according to the procedure (0 ohms resistance between the terminals of the Magnetron and its metallic case). But I also wonder if I have another bug in the oven since the oven simply stops before the alloted time period is reached. I suppose I am trying to understand what regulates the timer in the microwave circuitry and why the oven would stop prematurely. Could a defective Magnetron unit have affect on this timer circuit?
    Thanks for the help!! Good job!
    Genius:
  • 1,665 Answers
My microwave stops after 3 seconds
Saved me a possible big repair bill. Thank you.
Jun 04, 2014 | Panasonic NN-T994SF Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Panasonic NN-651W microwave gone dead
There si a place called encompass parts that is a distributor for Panasonic, Look them up or call them with your model number and check price and availibility on the PCB
Oct 18, 2017 | Panasonic Microwave Ovens
Panasonic microwave oven cuts on for two seconds then shuts off
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Nov 03, 2011 | Panasonic NN-T994SF Microwave Oven
Describe your panasonic microwave oven NN-CD997S Problem - wave guide cover fell off . oven still under warranty but panasonic are telling me that it's not covered under warranty even if it's only...
If indeed you have an extended warranty that covers this situation, you go to the outfit that sold you the warranty. Could have been the store where you bought the unit. Or you could check out the unit on ebay and hope that parts are available for it inexpensively.
Sep 14, 2017 | Panasonic NN-T994SF Microwave Oven
My Panasonic NN-T994 Microwave oven died today. Would run for a few seconds with a clicking sound and an electrical smell. I removed the cover, restarted and found arcing from the area of what I think is...
From your description it does indicate a magnetron problem, you would be further ahead replacing the microwave oven when you consider the expense of the repair involved.
Feb 23, 2011 | Panasonic NN-T994SF Microwave Oven
Time set does not complete
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
May 26, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic Microwave Convection Oven Model NN-8501Vstops after one min. of operation-Display goes to all
If you unplug the ac power cord , wait between 30 and 60 seconds and then replug the cord in, push the reset button and then select the time ot cook desired followed by the start button, it seems to work fine for a while (days) and then for some unknown reason it stops after one minute of operation and returns to all eights on the display. A real mystery as to why this is happening and what is really wromg with the unit.
Jul 25, 2008 | Microwave Ovens
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Microwave Ovens Logo
169 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
