Question about RCA T13208 13 in. TV/VCR Combo
LEFT BUTTON ASSEMBLY
WHERE CAN I FIND A LEFT BUTTON ASSEMBLY FOR THIS UNIT ...THE DESIGN IS WEAK AND THE OFF AND ON BUTTON/LEVER SNAPE OFF OF THE PLASTIC ASSEMBLY
 RCA Part Number 247221.  OR RCA 251640
I had the same problem i ordered it from this site $10
https://www.vancebaldwin.com/webwiz/wwiz.asp
Posted on May 24, 2008
Powered(verified) but not turning on. i broke the lever on the on/off switch. i have ordered a replacement but how does that lever give it power? there is not any electrical wires or contacts. TE1000
That lever give its power by a magnet only for the direction to turn left or right a magnetic switch is in the electronic assembly build in there is your point a part like this picture is builded inside the electronic assembly that electronic part can maybe a complete unit to replace for repair .
hilti service manual te 3000 avr pdf 1 Docs Engine com
Jan 13, 2016 | Drills
How do I replace headlight?
Some one posted this on newbeetle.org.
Quote....."
1. Open the hood.
2. Now look down into the front corner of the engine compartment to where the headlight is. You will see a black assembly tucked up in the fender.
The whole headlight assembly is close to 8" long. Since the driver side light is more interesting we will do that one. Yes you can get the drivers die headlamp out without touching the battery. I replaced the driver's side low beam lamp without removing the battery.
Before trying to do the next step of the black lever you must release the metal clamp flip the small coat hanger looking shaped like an M up this releases the metal strap around the headlight assembly bucket now press the button next to the lever the button has a crosshatch design on the small button about a half inch by quarter inch.
You must find the button if you try to move the black lever up without pushing in the small button you will break the lever and then you will be off to VW to buy a new headlight bucket assembly. In my '99 Beetle there is a lever that sticks out of the headlamp assembly shield.
Lifting up on the lever rotates a ring that unlocks two posts on the headlamp assembly. It can now slide straight out of the fender. The assembly rides on three tracks left side, right side and bottom.)
3. There is a black metal strap and clasp around the assembly with a metal clip on it. The clip flips back and opens up. There is also a black plastic lever sticking out of the assembly.
Next the clasp and metal strap you will notice the lever that expels the light assembly. Mine was curved indicating that you pull up on it. As you do so the lever slides you will see the headlight start to come out of the fender.
4. Once the lever is up as far as it can go you can pull the headlight assembly out of the front of the fender carefully. This was a bit messy since the caulking on our 98 was starting to go and the dealership had put some goo around it to stop leaks I think. The light assembly in our case did take some coaxing to get it to slide out and we had to play with it for awhile, but it did finally come out
5. On the back you unplug the wires.
6. There is a plastic cap that comes off and you can access the headlight bulbs
7. After the housing is off, you will notice the lamp connector. There is a spring or hasp that keeps the lamp in the housing.
8. We had to change the low beam lamp (the one on the top of the assembly), so once the clip was removed the lamp can be pulled out of the assembly..
9. Once the lamp is pulled out you are almost done. The lamp is connected to the wires with a blade type connector. Just wiggle it from side to side to remove it. Take the new bulb (DO NOT TOUCH THE GLASS ON THE NEW LAMP, if you do it will be ruined and you will be replacing it shortly). Once you placed the new lamp in, you can follow the instructions in the reverse order to put things back together.
10. When you are totally done, before you hook the battery back up and totally button things up, try the new light out quickly to make sure its working. All done." Unquote.
Jan 12, 2011 | 2001 Volkswagen Beetle
Keeps saying 'no disc' or 'invalid disc'
The Laser Pickup Assembly is the problem, the laser eye is weak and can not read the disc. If you take a Q-Tip and rubbing alcohol carefully clean the laser plastic lens allowing several minutes to dry. If after all this there is no change the only option is to replace the entire unit, because the cost of repair would not be justified.
Jan 07, 2011 | RCA DRC6338 Portable DVD Player
The sides of my Avalon play yard Ap14 will not collapse. I have lifted up the centre & pushed on the white dots but the sides will not go down. Please help!
We encountered the same problem. Our diagnosis: we **** open one compartment to see what was going on. The problem appears to be one that involves both parts and design. The plastic cams do not function symmetrically, due partly to a weak spring, and partly to design. This can allow one or both of the cams to lock in at an angle that is too stiff for the push button (a plastic lever) to overcome with mere finger pressure. we had to pry them loose with a screwdriver. This same combination of parts and design can create the opposite problem: difficulty getting the arms to lock into place. It also creates frustration trying to fold the unit up for storage as one or more arms can re-lock very easily. Solution: Returning it is probably the best option.
Dec 24, 2010 | Avalon Baby Gear
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
I need to change the headlight bulb on the drivers side of my 1999 beetle
Here are 10 easy steps!
1. Ok, pop the hood. 2. Now look down into the front corner of the engine compartment to where the headlight is. You will see a black assembly tucked up in the fender. Yes you can access the inner fender from the engine compartment. The whole headlight assembly is close to 8" long. Since the driver side light is more interesting we will do that one. Yes you can get the drivers die headlamp out without touching the battery. You can replace driver's side low beam lamp without removing the battery. Before trying to do the next step of the black lever you must release the metal clamp flip the small coat hanger looking shaped like an M up this releases the metal strap around the headlight assembly bucket now prees the button next to the lever the button has a crosshatch design on the small button about a half inch by quarter inch. You must find the button if you try to move the black lever up without pusing in the small button you will break the lever and then you will be off to VW to buy a new headlight bucket asembly. In '99 Beetle there is a lever that sticks out of the headlamp assembly shield. Lifting up on the lever rotates a ring that unlocks two posts on the headlamp assembly. It can now slide straight out of the fender. The assembly rides on three tracks left side, right side and bottom.)
Next the clasp and metal strap you will notice the lever that expels the light assembly. It will be curved indicating that you pull up on it. As you do so the lever slides you will see the headlight start to come out of the fender.
4. Once the lever is up as far as it can go you can pull the headlight assembly out of the front of the fender carefully. This was a bit messy since the caulking on our 98 was starting to go and the dealership had put some goo around it to stop leaks I think. The light assembly in our case did take some coaxing to get it to slide out and we had to play with it for a while, but it did finally come out.
8. Change the low beam lamp (the one on the top of the assembly), so once the clip was removed the lamp can be pulled out of the assembly..
Oct 13, 2009 | 1999 Volkswagen Beetle
HOW TO INSTALL THE DRUM UNIT for ir2230 copier
Open front cover of copier. Rotate lever (I think it's blue) to lower transfer/transport assembly. Rotate Developer/Toner assembly handle to move assembly away from drum unit. There is either a phillips screw or a plastic gripped screw that needs to be removed. Then, carefully, pull the drum unit 2/3 of the way out. At this point, the back half of the unit needs to be supported while pulling the rest of the way out. Open new drum unit. Remove all packing materials with red tag attatched...especially black paper covering new drum surface. The new Drum Unit has guides on top that line up with guides in the machine....carefully insert unit in copier until it seats FULLY. Reinstall screw to front of unit. Rotate Developer/Toner Assembly lever to cam back against Drum Unit. Rotate Transfer/Transport Assembly lever to lift assembly upward and latch. Close front cover.
Jun 13, 2009 | Canon IMAGERUNNER 2230 Copier
Need small plastic piece for Konica Minolta Magicolor 2430dl
The part is probably one of the envelope levers. This is part of the Fusing unit which comes as a complete assembly. Individual parts are not normally available separately.
Apr 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
Removing the inside door lever, front driver's side
some of them have plastic hooks on them also try sliding it up down left and right it should pop loose and you will be able to pull it out
Nov 13, 2008 | 1992 Honda Accord
My Minolta 7000 camera's rewind switch won't budge.
I have seen this on several of these, a small bit of plastic breaks off on the top cover and jams the rewind switch assembly.
To repair this you would have to take the top cover off and then remove the rewind swtich assembly from the top cover remove the bit of plastic and hey presto. You will find after removing the bit of plastic you will have to hold the lever to keep the camera rewinding, the lever will no longer stay in place as it used to (the bit of plastic held it in place)
Post back re Palmyman if you want to attempt this
Oct 12, 2008 | Minolta Maxxum 7000 35mm SLR Camera
RCA T13208 13 in. TV/VCR Combo Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
