Question about Hayward 1 Hp 2 Speed Super Pump Inground Pool Pump ( Ssp2607 102 ) ()
Motor humming will not turn
Motor will not turn how do i free it up
    Guru:
  • 351 Answers
You can undo the bolts that are holding the motor to the pump. That will let you spin the impellar of the pump .. Please withdraw it slowly and observe how the extra pieces fall out because if you get them in wrong the pump will not work correctly, While you have it apart , try and spin the impellar and switch the motor on , seeing if it will run if you hand start it .. if it will not run , then you probably need a new motor .. Most pool shops can test the motor for you to confirm that .
Please Vote !
Posted on Jun 05, 2010
What causes Electric dryer to not start & run
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Apr 04, 2015 | Dryers
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Dryer drum does not turn, but makes humming noise.
It is possible that the motor is struck up or the main spindle to the drum assmebly with bearings has jammed. This makes the motor hum and not start up.
The other possible problem can be if the capacitor to the motor is faulty.
So remove plug and manually turn the motor and drum , if the system is free then you must check the capacitor.
Aug 09, 2011 | LG DLE0442 Electric Dryer
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Dryer won't start but makes a humming / buzzing noise when you push the start button
If the humming noise is coming from the motor, (take the back panel off) remove the power plug and try to turn the motor by hand. If it seems free, look for a 'starter' capacitor on the motor which may be bad.
Oct 11, 2009 | Dryers
Opener will hum but not engage the drive train.
If the humming you hear is the motor running you need to remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. If it is the motor humming but not turning you have a bad start capacitor which is held by a bracket and is next to the motor.
Sep 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Hayward 1 Hp 2 Speed Super Pump  Inground Pool Pump ( Ssp2607 102   ) () Logo
151 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
