Question about Roper RAS8445KQ Top Load Washer
I am not sure what model Roper i have, but it stops when it hits the rinse mode? After a while, it will start again, then stop. Please help?
  • 1 more comment
  • p3dj86 Jun 05, 2010
    Where do i find the model #?
    What a total waste of $13.00!
    RAS8333RQ0
    Does this sound right?
  • 15,935 Answers
The timer seems bad - but without a model # - Its as far as this process can go.
The timer must be replaced for it to work properly.
Thanks!!
Posted on Jun 05, 2010
    Where can i find he model #?
  • blueextc3221
    blueextc3221 Jun 05, 2010
    Usually on a tag.
    Sometimes under the lid - sometimes on the back of the machine near the top.
    Check it and let me know - and I'll search for the part.
    Thanks!!
Why does my washer stop after the rinse cycle and doesn't advance to the spin cycle?
only a guess but sounds like the control board or the timer is going bad .stating make and model usually helps
Feb 02, 2016 | Washing Machines
Washer only works20 seconds then stops
Maybe at 10 years+ of service it is time to stop dumping money into repairs and buy a replacement.
Mar 14, 2017 | Roper Washing Machines
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer stops mid cycle
theres contact points in the timer and down below wherer the wires go into the motor. check them and if you find them to be corroded you canm clean the with emery cloth then reassemble the unit.
Oct 15, 2008 | Roper RAX4233PQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
"Check Water Tap" error
rinse valve possibly open circuit or external water pressure low
Feb 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
43 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
