Question about Eureka WhirlWind 4381 Upright Vacuum
How do I change the belt on a Eureka clean living vacuum model 3281AZ
DaVincii
  • 17 Answers
SOURCE: Eureka vacuum belt how do i replace on model #4688
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Posted on Feb 14, 2008
reddevil6
  • 1673 Answers
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
SOURCE: belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
Posted on Feb 07, 2009
  • 43 Answers
SOURCE: how to change belt on eureka vacuum 2996
The information you're looking for can be found on page 8 of the manual via this link: http://www.eureka.com/service/manuals/80244.pdf
Posted on May 06, 2009
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dec 31, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you change the belt on a model 5856
here is a link to the manual which has instructions and to the belts you need
Eureka 5856 Belts
Eureka 5856 Owner's Guide
Nov 22, 2009 | Vacuums
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Eureka WhirlWind 4381 Upright Vacuum Logo
1,200 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
