Question about Mitsubishi WS-65809 65" Rear Projection Television
MITSUBISHI 65" WIDESCREEN MODEL WS 65809 (GREEN GONE, SMALL RED LINES)
THE T.V. WORKS JUST FINE BUT THE GREEN IS MOSTLY GONE, AND IT HAS LITTLE RED LINES ON THE SCREEN!! PLEASE HELP!!!
    Scholar:
  • 170 Answers
In the front cover turn up screens on all colors till you see retrace lines, then back them down to where dissappear. enless you know the correct voltage to set it. as for the green. i would try the red crt on the green and see if it looks ok. if so then replace crt circuit or check transistors on crt circuit may also need to change the driver on the heat sync.
Posted on Apr 09, 2008
THROW IT OUT THE WINDOW AND SHOUT FIRE IN THE HOLD
Posted on Apr 10, 2008
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Where do I buy these little green 125Vac 5amp fuses for a Mitsubishi Ws-65809 tv set?
they are called "picofuses" you may find them at some on line electronics stores like partstore.com or you can call your local electronic supply store.
Jan 12, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have little boxes at the bottom of my screen. They appear when there is a light picture on the screen. Three rows of small rectangles. Help! Mitsi 65 that just got the blinking green light fixed.
you're probably used to watch tv with le closed captioned on. On big sceen tvs, the closed captioned text will burn the 3 crts (green, red and blue) it is written on the first page of your owner manual and there is nothing to do to fix it. it would very costly. sorry
Jun 30, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Tv will not turn on manually or with remote
you need to get the stk chips replaced. i had it done with mine, it cost me 411 dollars for a tech to come do it. it worked fine for about 4 months now, and my red color is gone. mitsubishi sucks, sorry : (
Sep 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
WS-65809
GO TO WEBSITE OF MITSIBUSHI
Sep 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSUBISHI 65"
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
