Question about HP LaserJet 3050 All-In-One Printer
Paper comes out black when printing and copying.
The printer does not copy or print anything. The paper comes out completely black with waves of gray and black across the paper.
    President:
  • 548 Answers
Change the toner from the cartridge and put new developer in it. Uninstall and install again the cleaning slide and for safety change the corona wire. It should work without changing the cartridge.
Posted on Jun 06, 2010
    Brigadier General:
  • 4,090 Answers
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 05, 2010
Ajbennett@gvec.netI have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Apr 08, 2011 | Cameras
I cannot get the printer to copy anything, it just goes into the align mode. It will print things from my computer.
Start up your multi-function printer and computer. Wait until it has powered on completely before beginning.
Open the printer's lid and place your item on the copying surface with the side you want copied face-down on the glass. Double-check the alignment.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed.
Choose the kind of copy you want: black-and-white or color. You also may have to select the kind of paper that you are copying.
Size the copy to the page if desired. Some multi-function printers allow you to expand or shrink the original to fit different sizes of paper.
.Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Press the "Start" button. Other names for this might be the "Copy" or "Print" button.
Remove the pages as they are delivered from the printer's feeding mechanism.
Do not tug on the copies as they come out. Let them fall into your hands.
Take care.
May 15, 2010 | Office Equipment & Supplies
Document copied in black & white prints
Check Printer Settings in computer for Resolution. if its print resolution is low then it will print very light gray.
Check Toner / Ink Cartridges for ink also.
To check resolution go to printer Properties by right clicking printer (from Control Panel>> Printer and Faxes) .
Mar 22, 2010 | Audio Players & Recorders
Blue Color On Copies
Check your settings for copying through your printer software.You might have accidentally messed up some copy settings there (Contrast, etc.)
Rollers do not have anything to do with this because your regular prints and copy prints are fed through the same roller.
Try removing your printer from Device Manager. Completely remove your printer software and reinstall all this stuff like you're installing a brand new printer. There is a 90% chance that your printer will be find after this.
Hope that helps.
Feb 19, 2010 | HP Officejet K60xi-Printer/Fax/Copy/Scan -...
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
352 people viewed this question
Seeker5211
Seeker5211
