Question about Craftsman Air Tools & Compressors
I have a craftsman air compressor with 25 gal horizontal tank. There is significant air leakage under the guage head. Are there seals I can replace?
    Problem Solver:
  • 18 Answers
Toss the gauge, if they leak internally then the brazing inside has come loose, the gauges aren't that expensive. Good luck, and sears parts direct should have that gauge
Posted on Jun 05, 2010
Air compressor model no. 921.153101 blowing air trough air cleaner
If you get air movement out of the air cleaner and it only compresses air to 25psi, you have bent or broken reed valves in the head. Take the head off the cylinder and inspect the valve plates and reed valves. This is a Craftsman compressor so you'll most likely have to get parts through Sears at www.searspartsdirect.com. For best results replace everything between the head and cylinder; gaskets, valve plates and reed valves.
Oct 03, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 6 gal, 150 psi craftsman compressor. There is a leak under the plastic housing. How do I seperate the tank from the compressor?
This product manual will show the exploded view on how it comes apart/goes together:
http://c.shld.net/assets/own/00915216e.pdf
Jan 06, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor runs, but no air pressure builds in tank
Three things to check.
1) Check that the tank drain is closed
2) Check that your quick connect fitting at the discharge of your compressor is sealing properly.
3) There is a copper or aluminum line that goes from the head of the compressor to the tank. Check the fittings on each end they occasionally come loose due to vibration.
If all of the above is ok:
Check the head gasket of your compressor. The unit you have is notorious for blowing head gaskets.
Hope that helps,
under_psi
Aug 31, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
25 gal horizontal craftsman air compressor is leaking at the pressure control valve. Can I replace the valve or repair it?
Unloader valve probably needs to be adjusted. Should be two jam nuts holding the unloader to the pressure switch. Loosen the jam nuts and adjust the unloader slightly away from the lever. Tighten the jam nuts and try it again.
May 21, 2010 | Air Tools & Compressors
I have a 25 gal compressor and it will not build pressure. The motor runs but will not build pressure. The compressor is about 25 years old
You got a good life time with this. The compressor has seals or "rings" which wear out over time. Replace them and your compressor will love you. It won't hurt to check all the lubrication points. This procedure is easy for even a novice but may require a special tool. Go to your local small engine repair shop and ask. They will be glad to help you.
Aug 05, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal ari compressor low presure
put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
Apr 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Mar 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
69 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
