Question about Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1350 is not working, I put it on and it just says loading maps, I have plugged it into the computer but it does nothing just turns on and has a green line across it
SOURCE: Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Posted on Jun 20, 2008
pabloloco
  • 2335 Answers
SOURCE: Garmin Nuvi will not load maps - why
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
  • 54 Answers
SOURCE: My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
Posted on May 03, 2010
SOURCE: garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Posted on May 10, 2010
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
Nov 06, 2013 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Nuvi 1350 stuck on loading maps. I alreadt reset
The nuvi 13xx series did have this issue, if you are unable to reset it and connect it to the PC to update the firmware using Garmins WebUpdater it will have to be sent to Garmin for warranty.
Hope this helps!
Dec 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
617 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
