Question about Mitsubishi HC3000U Multimedia Projector
Mitsubishi hc3000 just turned off while we were watching. It tries to turn back on with the usual whirring sound(Fan?) but then makes a couple of clicking noises and fails to go on. Just goes to red constant with green blinking light. New lamp about a month ago.
  • 4 more comments
  • Rishabh Jagga Jun 05, 2010
    JUST CHECK THE POWER FUSE OF UR PRODUCT
  • griggeric Jun 05, 2010
    It's getting power. Like I mentioned it sounds like usual startup(spinning sound like a hard drive on a computer), but then an unusual clicking then nothing just constant red w/ green status.
    Can you tell me how to check the fuse? Where is it located?
    Where can I access the fuse?
  • griggeric Jun 06, 2010
    Power steady red with green flashing status light. Manual just tells you to hit power button when status stops blinking. This just starts the process again. The tv seems to be trying to start up normally(fans start power light comes on), but then thats when I hear that light clicking sound and the red with green flashing starts.
  • griggeric Aug 22, 2010
    Check your bulb. That was my problem. Even thought the new bulb was only about 30 days old, it was toast. I also discovered that the bad bulb was a generic. Buy the philips brand oem bulb. It has worked flawlessly!
I'm sorry that I don't have a solution. I have exactly the same problem! Can you tell me how you ended up fixing it?
Posted on Aug 22, 2010
    My trouble was a bad bulb. Even though it was only about 30 days old. Don't buy the generic brand, get the philips oem bulb.
  • 75 Answers
Have you cleaned the filter. The lights do provide an indication if you look in the troubleshooting guide in the manual.
Posted on Jun 05, 2010
  • ridinghood Jun 06, 2010
    if it was the fuse you would get nothing...no lights etc. Fuse is inside the unit, remove the cover look around where you plug the power cord to the projector. Typically they put ceramic fuses and you will need a volt meter to check if it's good or bad. or just buy the same characteristics fuse and swap it and turn it on. If you could tell me what color are the lights blinking and what are the locations i.e. lamp, power, etc. i can look these up to tell what is the issue.
  • ridinghood Jun 07, 2010
    The clicking sound could be the HV spark gap firing which means if you put in a good lamp the projector will work, but you have changed your lamp. I don't think it's your ballast because of the clicking sound but it may be a possibility. You can sometimes check the operation of the ballast by removing the lamp, replacing the cover and trying to turn it on. You should hear a faint tick, tick, tick, This is the HV spark gap firing.
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
Fan noise
HELLO!!
BASICALLY WE CLEAN THE CPU FANS REMOVING THE CPU FOR MINIMIZING NOISE ... CAN U TRY THIS ???
Jan 03, 2008 | Mitsubishi HC3000U Multimedia Projector
MY SAMSUNG SRS584DP IS FRIDGE FAN IS ICING UP AND MAKING A WHIRRING SOUND
does it have a summer setting. turn temp down just a little is frezzer overpacked check for build ups of ice in corner some have holes to alow proper cool air circulation.
Sep 27, 2012 | Cell Phones
Unit turns on but fan does not work. When we turn unit on, it makes a low "whirring" sound, but no air comes out of unit.
Try turning fan by hand. If it turns easy, replace fan capacitor.
If hard to turn, replace motor.
Jul 11, 2010 | Frigidaire FAH125P2T Air Conditioner
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
Mar 21, 2010 | HP LCD Display for Compaq Presario R4000
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
I have a mitsubishi WD-57731 57 In. DLP. When I power it up I get no or video it makes a whirring light clicking electrical sound in the back. The timer indicator flashes green for like 20 secs or so when...
The whirring is the fan. The clicking is the spark gap on the ballast releasing the unspent voltage trying to fire on your lamp.
Check your lamp; it may be unseated (unlikely) or just blown/bad (likely).
Jun 15, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Mitsubishi HC3000U Multimedia Projector Logo
672 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
