Question about Car Audio & Video
My 2000 watt 2005 performance technique amp red light came on.. what hapened to it?
  • 74 Answers
It went into protection mode. Try to unplug any speaker connected to it and turn on. If the red light doesn't come on you ma have a problem with your speaker
Posted on Jun 08, 2010
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
Apr 25, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
No knowledge of how to hook two subs which are the 12 alumni audiobahn sub to a performance technique 781 mono block amp operation ohms for the speakers say 3 or 12 ohms during operation can i bridge or do...
yor subs have dual 6 ohm voice coils from the sound of it-your amp is rated at 650 watts rms at a 1ohm load. The best you can do with the equipment you have is to wire ALL the coils of your subs in parallel and that will give you a 1.5 ohm load for the amp.It should knock the hell outta them with 300 watts on each sub - good luck
Jan 14, 2010 | Performance Teknique ICBM-782 Car Audio...
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
The light yellow is on what hapen whit my ampli
Depending on what light it is. It could be your ohm light, if it is your ohm light then you have something wired incorrectly. If it is another light, it could either be a power problem or it could be that your amp is damaged.If you would like, you may e-mail me and u can let me know which light is on. It SHOULD say right next to the light; which light is on. E-mail me at epayne123@yahoo.com and I will respond to you as soon as i recieve it.
Oct 30, 2009 | Jl Audio 300/4 Car Audio Amplifier
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
