Question about Maytag Neptune MAH6700A Front Load Washer
Hi! getting od error and waher will not let me start any cycle
  • 327 Answers
Hello, the "od"error you getting means the control did not detect that the door was opened between washes. Try opening and then closing the door again and if the error message is still present, there may be a problem in the door switch mechanism, the electronic control or the wiring between the two.
Thanks
Posted on Jun 05, 2010
Od error code
The Neptune Od code will come up when the unit does not see the door opened before starting another cycle following a completed cycle. Simply opening the door and closing it again will remove this code until the same incidence happens again. So if you are looking to rewash a load of cloths you must first open the door then close it before you can start the machine over. Pleazer Appliance...
Apr 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have od on my control panel what does it mean
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
Dec 01, 2010 | Maytag Washing Machines
I get OD code
od meaning from the Service Manual for the FAV6800A/FAV9800A;
Open the Lid: The lid has not been opened for the last three completed cycles.
The OD and OP error codes are trouble shot the same way. See if this link will help.
Left Hand Lid Lock Troubleshooting
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........D*ick
D*ick
Aug 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Waher will not start
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Oct 05, 2009 | LG WM0642H Front Load
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Front loadder steam waher says IE in the middle of the cycle and stopped running
IE = Inlet Error. Check inlet screens inside where hoses connect to the machine. (most likely the cold inlet screen is plugged)
Sep 17, 2008 | LG Washing Machines
Error Code "od" while trying to start machine
Could od mean overload? Reduce or actually weigh load and re-try
Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
