Question about Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer
Dryer not spinning
Have tried unplugging.
  • Fisher and P... Master
  • 43,501 Answers
There can be many reasons why your dryerDryer not spinning - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
DryDryer not spinning - 2_bing.gif="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 05, 2010
Heater not functioning
Hello, does the dryer drum spins? If so, then replace the heating element in your dryer. Look on the back of the dryer, if there is inspection plate about 10"x10". First, unplug your dryer, this is very important to your life. Once the dryer has been unpluged then remove the inspection plate.
Now, if there isn't an inspection plate on the back of your dryer. The the front of the dryer will need to come off. Just leave the dryer door on. Turn the dryer on it side---Remember to unplug your dryer--- On the bottom of the front dryer panel with the door is three or 4 screws just remove these screws. Now, pull the bottom the dryer front panel out about 2" or 3" and pull the front panel down. There is two snap locks that are hooked in the top of dryer cover. Pull the dryer panel out and reach in aroun the door to unplug door switch. I hope this work out for you. GB...stewbison
Sep 23, 2011 | Dryers
Dryer is on and door correctly closed. Wont spin or produce heat. Have unplugged to try and reset but no use.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Samsung DV218AEW Electric Dryer
Dryer makes a noiseand ther is a smell like somethings burning,drum doesnt spin
Sounds like a classic case of a bad drive motor.
I would unplug the dryer, remove the dryer belt and try to turn the motor by hand to see if it's tight or locked up.
Aug 02, 2011 | Frigidaire Dryers
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
It was working fine. All of a sudden, the dryer stopped. When I press the start button I hear a buzz or grunt sound, but the drum doesn't spin.
Hello- Its possible that there is a bad start relay or switch but most likely the motor is bad. Try spinning the drum by hand, if it doesn't spin there may be something (a sock) stuck in the blower motor. You would have to take the machine apart to determine this. Depending on the Make and Model it could be difficult, or not. Just BE SURE if you open anything up the dryer is unplugged. Good Luck
Sep 24, 2010 | Dryers
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
DRUM WILL NOT SPIN, BELT IS OK
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
Nov 08, 2009 | Whirlpool LGR6611L Gas Dryer
Dryer spins no heat?
Inside the tub in the dryer itself is a heating element behind the screen. Try replacing it. Unplug the machine first though.
Aug 22, 2009 | Whirlpool LGB6300 Gas Dryer
Duet dryer
be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
May 28, 2008 | Dryers
Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer Logo
70 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
