Question about Troy-Bilt Pony Garden Tiller
MANUAL FOR TROY BILT TILLER
I HAVE SERIAL NUMBER AND MODEL # BUT CANT FIND ANYTHING S/N:420766 MODEL:TH-1002 PLEASE HELP
3 Suggested Answers
Loringh
  • 185 Answers
SOURCE: need a repair manual for troy bilt tiller
Ddavis:
Have a look on ebay. Do a search for troy bilt tiller manual. There are several folks on ebay that collect and sell on manual on all kinds of stuff. I was able to locate a manual for an old singer sewing machine.
Hope this helps Good Luck Loringh please leave me a rating Thks
Posted on Nov 11, 2008
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
Have a really old Troy Bilt rear tine tiller, serial number is gone, I did find TH 1003 stamped on the housing. It has a Hohler 7 HP engine. I'm trying to locate the proper belt, and possibly an...
Without the exact model you will be hard pressed to get either. For the belt, you can wrap a rope around the pulleys and measure the circumference. That will tell you the belt size in inches. You then measure the width and you will have that information to give to a parts supplier. There are enough fans of the Troy Bilt tillers out there so you may still get lucky and find someone that knows what the model is from your description. Hope this helps to at least make the tiller usable. Good luck.
Jun 28, 2011 | Troy-Bilt Garden
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
I lost mt manual to my tiller. how do i get another manual?
If you have a Troy-bilt tiller, go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Enter both your model number and serial number to access the manual online. If you want to order one, the price will probably be $10.
The model and serial number are likely on a plaque on the tine housing.
I hope this helps.
Mar 22, 2011 | Troy-Bilt Garden
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
I need a free owners manual for a troy bilt pony rototiller model number 12211
Go to the above website and type in 12211 for your model number and 1 for your serial number. You will be able to download a free copy.
Frank
May 20, 2010 | Troy-Bilt Pony Garden Tiller
How can I get a Owners Manuel for Troy Bilt Tiller Seril no. 722649
Hi and welcome to FixYa. I am Kelly. We need the exact model number to be of any help in trying to locate a manual for you.
If you have your model and serial number you can use this link.
Thanks for using FixYa.
Kelly
Apr 23, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Where do I find the model number and serial number, it is an old troy bilt rear tine tiller, two speed
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
Apr 23, 2010 | Troy-Bilt Pony Garden Tiller
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
239 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
