Question about SanDisk Sansa Fuze MP3 Player
I can't get my Sansa MP3 player to charge
I plug it in to my home computer with the USB cable, it turns on and looks like it's charging but after 48 hours it's not charged. Can you help me out?
    Problem Solver:
  • 4 Answers
Hi, 48 hours later , the player has sucked in enough electricity ! Thank you , Linda
Posted on Jun 05, 2010
How do you charge the battery?
MP3 players are usually charged using the supplied USB cable. Connect the USB cable to the MP3 player and then plug the other end of the USB cable into the USB port of a working computer.
Jun 01, 2012 | SanDisk Sansa c200 MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
I dont know how to charge my mp3 player and its dead
Plug one end of the supplied cable into the slot in the bottom of the Sansa. Plug the other end into a USB port of a computer. Make sure the computer is turned on, and it should start charging.
Mar 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do i charge my mp3 player/sandisk sansa m240
Connect the USB cable to the MP3 player then power up a computer and plug this MP3 and cable into the computer's USB port.
You can also charge it by purchasing a 5V USB power adapter and plugging the MP3 player and cable into this adapter.
Jan 04, 2010 | SanDisk Sansa m240 MP3 Player
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    My sansa wont turn on
    well did u make sure it is fully charged if so den plug it into the computer
    Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
    Check for the following:
    USB Cable
    Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Battery
    Latest firmware
    Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
    SanDisk Sansa Fuze MP3 Player Logo
    220 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
