The power cable is plugged into my Compaq presario v4000 laptop but only charges when I move it. I keep a support against the charger while plugged in to keep it charging. However, If I just left my laptop with the charger in then the battery icon will show until I place a support under the charger. Basically, the laptop only charges when i manually adjust the position of the charger cable. The charger cable is fine as I have tested it in my brothers laptop which is the same model. I can only assume it is the laptop at fault
    President:
  • 2,351 Answers
The internal plug is worn / bent. Or the notebooks connection is loose. You can try to bend the power pins (ever so slightly away from each other). So when you plug in you're adapter it maintains a tighter fit. Do this with the power off. The next step is to replace the notebooks power plug.
Luck
Mike
Posted on Apr 09, 2008
    Guru:
  • 1,342 Answers
Unable to charge computer. I plug it in but it will not light up or charge.
There are two possible reasons for this. The first is a bad power cable, the second is a bad power supply. A cable can usually be replaced on the cheap, but if it is the power supply, it will cost a bit more. Unfortunately, the only way to be sure is to try another power cable, which can be hard to find without buying.
Mar 14, 2011 | HP Compaq Presario v4000 Notebook
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Would a compaq presario v2000 screen be compatible with a compaq presario v4000 laptop. one of my cats juped onto my closed laptop and now there are two big black blotches and cracks across my screen so im...
Its not compatible. It has different screw listings then V4000.
If you could provide me the product No. which is at the bottom sticker of the notebook of your Compaq v4000 laptop then I can find the part no. for LCD screen which is less costlier and exchangeable.
May 31, 2010 | HP Compaq Presario v4000 Notebook
My HP Compaq Presario V4000 does not boot!
BOOT FROM NTFS BOOTABLE DISK.. TAKE BACKUP FROM C DRIVE. THEN RESTORE UR XP WITH RESTORE OPTION.. OTHERWISE FORMAT C DRIVE.
Apr 20, 2010 | Compaq Presario V4000 Notebook
Compaq Presario V3000 charger stopped working and now buzzes
Unfortunately there are no perfect cables, and especially in case of a laptop, when you move it around a lot, roll the cable for travel etc. it gets bent a lot, especially in the place where the elastic cable goes into the hard plug or into the charger case. The conductors inside and the inner insulation finally break, giving at first intermittent connection (what you experienced before), and finally short-circuits the cable, resulting in charger damage.
You should be fine just replacing the charger, unless all this wiggling around didn't break the laptop power socket.
When looking for a replacement charger, note the voltage of the original (it should be exactly the same in the new one), the maximum current amperage (this should be same or - better - higher than original), and the size of plug.
Good luck :)
Jan 23, 2010 | HP Compaq Presario v3000z Notebook
Connect Compaq Presarion V4000 to HD TV
get a monitor ext from any walmart or computer stor and plug it in your tv. there is a monitor plug waiting for you. you can do this my 12 yr old did it
Jul 02, 2009 | Compaq Presario V4000 Notebook
Computer wont turn on
it might be a bad power supply
Mar 12, 2009 | Compaq Presario V4000 Notebook PC
Play laptop video on tv
yes vga plays hd video. but an hdmi cable is better. get a VGA to HDMI cable
Jan 17, 2009 | Compaq Presario V4000 Notebook
Compaq presario v2000 wont charge
It has happened to me as well since i have the exact same model laptop. The problem is a loose cable or the wire inside is damaged. I just bought a new charger since buying one is cheaper than taking the risks that the repair might cause a short after using it for some time.
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
Laptop won't charge- have a compaq presario v4000- got a new charger which still doen't work.
hmmm...sounds like either the battery is deep discharged, or the motherboard isn't passing the charge voltage through to the battery..
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
