Question about Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB
I have a hayward 1hp pool filter/pump with the low pressure. I have tried everything i know from cleaning the fingers to checking valves/i just can not keep the flow strong. What do i do?
  • 1 more comment
  • A Miller Jun 05, 2010
    You don't mention what your pressure is ... are you getting sand into your pool? I would expect you should have around 15 lbs in a freshly cleaned filter. Do you have the proper amount of sand in the filter? Is your filter not cleaning the water? Low pressure is not necessarily a bad thing ... unless it is really low indicatind a very dirty sand bed with 'channels' in it. When was the last time you changed the sand? Does it have filter media sand or beach sand. Very important that you have swimming pool filter sand in the filter.
  • KEN LaPOINT
    KEN LaPOINT Jun 05, 2010
    can you give a bit more detail about your pool? Are you around trees? Do you have to deal with debris in the skimmer? thanks
  • Stephen Dorje
    Stephen Dorje Jun 06, 2010
    Did you install a revamp kit? Air in pump basket when runnign?
    Sergeant:
    Champion:
  • 333 Answers
Have you cleaned the filter?
Posted on Jun 15, 2010
Low water return flow
sounds like DE remove grids clean then recharge with DE
Jun 14, 2012 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Why is the pressure in my filter shooting on and off
Maybe low water or check your skimmer weir door and be sure it is free and not sticking in the up position.
Jul 13, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Pressure is running very high just cleaned fingers with acid and did not help we just had new liner put in pool is filled and have salt water system so there are no chemicals in pool yet because generator...
Depending where you live and how high your minerals run in the water. If it is old enough to change the liner it is probally old enough to get new socks for the fingers.
Jun 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I loose discharge water flow after about 5 minutes of running perfectly. The pump has no air bubble and is trying to push water thru filtration system ( if I open the backwash valve I have very good flow...
If you have a pressure gage it would help .. if the pressure is high then there is probably an obstruction in the return pipe to the pool .. if the pressure is low then there is most likely a restriction in the supply or suction side of the pump .. this would seem more likely to me from your description, there may be something obstructing the flow into the pump, a clog, a collapse hose from the suction, some flap of pool liner .. something like that ..
Please Vote !
Jun 01, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Hayward 1HP for in-ground pool: When I shut the pump off sometimes DE backflows from the filter through the pump and into the pool and accumulates on the bottom. The pump is about 10 years old and it just...
Usually caused by a small air leak somewhere on the pressure side of the system. A check valve on the line coming out of the pump going to the filter will solve problem.
May 05, 2010 | Hayward 1HP Super Pump II Inground Pool...
My hayward de filter will not filter over 1 hour
How much DE are you putting in it??? If it is a EC40 then no more than 4 small coffee cans of DE.
If it is an EC65, then no more than 6 - small coffee cans of DE. ( you can even shy back by a 1/2 of can of DE, without any problems.
Is the pool green??? If so, the filter will continue to plug up until clean.
Keep your Chlorine abit on the high side...DE filters run best with a chl reading of 3.0
Jun 20, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB Logo
230 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
