Question about Diesel Allis Chalmers 190xt Tractor Hydraulic Pump
Clutch Slipping or Hydraulic Problems?
We have a 190xt series 3. It seems like the clutch is slipping when you are in high gear and pulling a hill but I don't think it is the clutch. Also the pto doesn't seem to run fast enough. What could be the problem?
  • A Miller Jun 05, 2010
    Have you checked the condition of the drive belt?
  • 36 Answers
Try bleading the slave cylinder for the clutch
Posted on Jun 05, 2010
Mahindra 6500. Clutch seems to be slipping very bad in high gear and some in low gear. Is there an adjustment
If you have a hydraulic system , there is no adjustment. You didn't state a year. Adjustable clutch linkage went out in the 70's I believe.
Sep 10, 2016 | Mahindra Cars & Trucks
Freelander clutch
check out the operation of the clutch system .IT is difficult to rationalise a hydraulic clutch because if it is slipping that means that the pressure plate is being held off and not fully engaging but it also means that when pressing on the clutch the there would be no problem changing gears . But if you have a cable clutch operation then it is possible that the cable is jamming inside the outer cover and holding the pressure plate off ( slipping) and gear problems. If it is cable then replace the cable first. If hydraulic then it may mean box out for a new clutch kit.
Jan 12, 2014 | Cars & Trucks
My 1995 sentra shifts fine in all gears but when i accelerate in 4th or 5th gear it the rpms wind up and the car doednt real respond feels like its in the accelerater do i need a new clutch
Sounds like the clutch is slipping. If the clutch is bad, it will slip in high gears (4th & 5th) but seem to work fine in lower gears. Clutch probably needs replaced but have a mechanic check it out first because it's a fairly expensive job. If your clutch is actuated via a cable (not hydraulic), it may just need adjusting.
Dec 10, 2010 | Nissan Sentra Cars & Trucks
Slipping clutch when towing
Clutch is failing and will soon be slipping all the time. first up hills, then in high gears, then in low gears. time to start pricing out parts and labor is now.
Nov 22, 2010 | 2004 Hyundai Santa Fe
Is there an adjustment the clutch is slipping in 3rd 4th gears Or do you just have to replace 2004 aeiro suzuki
lower gear ration in higher gears, like climbing a hill, lessens the mechanical advantage and causes the slippage which will soon be in lower gears too. Clutch is hydraulic, not adjustable, you need a clutch replacement, along with all the other wear parts in the bell housing.
Sep 25, 2010 | 2004 Suzuki Aerio
Clutch slips badly in first gear,
Hi, this is a hydraulic clutch system.If the clutch is slipping, it is more than likely a worn clutch.If you had a hydraulic issue, the truck would be hard to shift, and the pedal would let out really low.It seems like you may be looking at a clutch replacement.Thanks...
Sep 22, 2010 | 2000 GMC Sierra
I have a 1988 4X4 pick up 4 cylinder. When i start to pull a hill the rpms go up and you can hear the engine revving up but the truch won't pick up speed. I thought the clutch might be slipping but I can...
I would suspect the pressure plate and clutch need replacing. Your truck is 22 years old and if it has never had the clutch replaced you can almost bet it needs a new clutch and pressure plate. It slips in 4th & 5th gear due to the fact the the ratio is high and it takes more pressure to hold the clutch in place.
Aug 16, 2010 | 1988 Toyota Pickup
Clutch slipping m4 golf
Best check for this is to get the car around 30mph, put it in top gear, and floor the gas. If the clutch is going to slip, this is when it'll happen. If it slips, you'll need to replace it. If it doesn't, there's likely no issue with the clutch and you'll have to look elsewhere for the problems you're seeing.
Aug 09, 2008 | 2003 Volkswagen Golf
Diesel Allis Chalmers 190xt  Tractor Hydraulic Pump Logo
586 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
