Question about Sharp R-1852 850 Watts Convection / Microwave Oven
Sharp carousel microwave, door button is pushed in
Sharp carousel microwave, model r-820b- I pushed the door button to open the door and the door opened but it stayed pushed in and will not pop out- the door will not latch close.
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
The carousel turns but no light comes on inside, not is there any display light. Nothing works but the carousel. Thanks
That sounds like there is more than one fault, but maybe not. I suggest you get an appliance engineer in to take a look at it.
Jan 05, 2011 | Sharp R-820B Convection/Microwave Oven
The push button that opens the door on our Sharp Carousel R-1406F over the range microwave, is broken. We can push it in but it gets stuck. I cleaned it out because it was kind of dirty but it didn't...
It may be the door open button or the door button lever. Sometimes grease is the culprit, other times the surfaces where these two meet get worn, making the door harder to open.
You can find the full service manual free at our site here.
You can find Sharp part at the Sears Parts Direct Web site hereimage-4235112-10659157 or Encompass here.
You can find links to helpful exploded view diagrams and part ordering help for other brands here.
Jan 01, 2011 | Sharp R-1405 / R-140 Microwave Oven
My door latch pushes in but does not open the door.
But does not what? If the door doesn't open, chances are the seal has gotten sticky so try to apply a little outward pull... If it is sticky and opens, wipe down with moist cloth both the seal and the mating surface.
May 29, 2010 | Sharp R-230 Microwave Oven
Sharp R-1852 850 Watts Convection / Microwave Oven Logo
121 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
