TV went out durring storm.It will power-up ,has dim lit screen,no video or audio.Have found no fuses blown or visual damage.If you haven't worked on this model with this type of problem then please don't just give a vague answer like i have been given like "Probably has a blown part inside" That is not a Expert Response. It's gona be a board,likr maybe the H SC or DG. Thanks rioconcho Panasonic Plasma TH-42PX60U
  • 505 Answers
I have worked on your tv many times.
if you can see that the screen is lit up somewhat, then you probably have voltages and scan (power board "P" board, scan board "sc" board), and other board are usually ok. if you truly had a surge, it came in through power or cable/video inputs. with your symptom, it likely did not come in through power, or you would just have a dead set. if it came in through your video inputs, it will usually just fry the video (main) board. we can look up the board part #s and "exact names" when we figure it out, but first we need to confirm.
can you see your tv menu?
does rebooting the tv "hard boot" snap it out of the issues?
-unplug AC power for 2 minutes, plug in, wait 30 seconds and turn it back on.
answering these questions will narrow it down.
also look closely at the screen, if you can see it kind of light up, but dont see any pixels "mis-firing", it just looks like a dark screen, then your power and scan and sustain boards are all likely good.
let me know, we can fix this
Posted on Jun 05, 2010
  • 1 more comment
  • earl mccain Jun 05, 2010
    Have tried to restart TV by unplugging,waiting,then restart,no luck on restart.Also menu will not pull up.I can turn set on and the whole screen does faintly lite up evenly all over the whole screen.
  • thielectronick
    thielectronick Jun 05, 2010
    well, looks like the signal part of the tv set has a few board
    the inputs are on the h board TNPA3769S
    with not menu (osd) you probably have more bad than that, but the surge likely came through there
    you're probably looking at the digital video board
    A20191-P01-H-K1 is the only part number i can find for it
    I would pull all that apart and see if i can find any burnt up parts or blackened traces
    if the surge came through the H board, it probably took that out too
    since there is no fuses or protection on the video side of the tv, surges over there can be a nightmare
    did anything else fail or get damaged by the surge? like cable or sat box?
How to fix the back-light on Phillips TV (40PFL4706/F7).
we had one doing this and took it apart. found one of the backlight diode lights blown, you could see it was burnt. ours had strips with led's on it. we found a number on strip, went to amazon and ordered one. it fixed it... so far
Jan 16, 2018 | Televison & Video
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
KDL 32II150 does not have a standby led lit.
Thanks for answering so quickly, I work with electronics but I have not done much TV repair. It would be a huge help to have more information. If it turns out to be my main borad are there firmware updates that need to be made?
Jul 03, 2013 | Televison & Video
My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Dec 31, 2012 | Audio Players & Recorders
I have a Sony KDF-E55A20 55 in. LCD Television, had a storm power outage, now tv has no audio, no video, but barcode colors on screen.
Main digital board has damaged. Replace it. It is a skilled work, as replacement to this board will need some critical adjustments. It will be best to get it replaced by the authorised service center for Sony.
Jul 09, 2012 | Sony Televison & Video
Vizio plasma tv will not turn on by button or remote, cable box is lit. We had a loss of power last night due to a storm. What do we do to check it.
hi usually the cause of won't power on problem due to the storm is the current fluctuation which the tendency is power supply failure. now since totally dead set what you need is to open the tv unit then look for the power supply where the power cord is connected. check obvious defective component part like blown fuse and burnt part like resistor and capacitor. just replaced with the same value and ratings to avoid damage from others component.if their is no problem with the power supply the output voltages are good the main board get damaged. good luck thanks for consulting the fixya.
Jul 14, 2011 | Televison & Video
TV has no power!
The TV may have experienced some type of " POWER SURGE ".
You can try leaving the TV unplugged for 30 minutes. That way the Tv can reset itself.
If that doesn't work, the odds are the power supply board has failed or a fuse on the board may have blown.
Jun 23, 2009 | Samsung LE27S73 27 in. HDTV-Ready LCD TV
PS3 Visual Effect Not Working
Heya Tllynn2200,
It is really unlikly that an electrical storm could of blown out just the visual of the ps3 without damaging anything else. I would say that your ps3 has just changed the output, Turn the ps3 off at the back switch leave it off for ten seconds then turn it back on using the back switch, Now with the on button at the front press and hold that button and let me know how you go, That will reset the display back to factory output and should display on any cable. Please let me know if this worked or not and will go from there
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
VIZIO VX37L --Power surge killed my tv!!
a power surge usually takes out the power supply itself
Nov 05, 2017 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
