Question about Mtd Garden
I need to replace a deck pulley spindle assembly for blade
I need to replace a deck pulley spindle assembly for one of the blades on an older ranch king(mtd) model# 136G699G205 serial# 2A196C30042
This is a 42 inch cut ride on lawn tractor.
How do I know which spindle assembly to order before I take it out?
It's raining and I can't work on it until it stops raining, but I would like to order the part now. I'm pretty sure it's a - 917-0906A spindle from looking at a diagram on the net, but I need to be sure. Is there a part# on the spindle?
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 996 Answers
If you have a owners manual it will tell you but if not go to your computer punchin make model and a choice of sites will come up also sears parts direct will help u on the phone or enter your modle make and a parts list will come up good luck hope this helps.
Posted on Sep 10, 2017
5 Suggested Answers
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 11, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace the star assembly that you attach mower blade to
You need a blade spindle or some call it a mandrel. Some remove the base to replace the spindle, but It's much easier if you drop the base to the lowest setting, loosen the nut for the pulley that is attached to the spindle. I didn't mention taken the belt off because it can be done without removing the belt. once the pulley is removed there are 3-4 bolts holding the spindle from the top of the base, take these bolts out and the spindle will come out. Not sure where you are from, but the cheapest i have found is EBAY. These are new, but a local ACE or somewhere like this may have it in stock.
Apr 06, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
MTD blade spindle problem
yes match it up from the one off of your other spindle and or take the sample to a hardware store and find something close that would do the job for you
May 03, 2009 | Garden
Garden Logo
153 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
