All my wires or off on the unit thats in side my house its 4 wires that hook up to the blower
    Scholar:
  • 45 Answers
Check the wiring on your thermostat. It should go something like the following.
RED to RED
WHITE to WHITE
GREEN TO GREEN
YELLOW to YELLOW
The 4 wire that we sell has red, white, blue, and green so our contractors wire it up by going blue to yellow.
Posted on Jun 05, 2010
How to replace blower wheel on Friedrich SL28M30 AC unit
follow this steps and fix it. God bless you
    • 1
      Turn the electricity to the air conditioning unit off at the
      service disconnect box. Follow the wires from the AC unit to the
      disconnect box, usually located next to the unit. Open the disconnect
      box and, depending on the type, either pull the buss-bar or flip the
      disconnect switch.
    • 2
      Open the air handler\'s access panels with the correct size of nut driver, usually 5/16- or 1/4-inch. Save the screws.
    • Remove the control panel\'s cover, if equipped, with a nut
      driver. Some models have a flat metal cover over the electronic
      controls, and some control panels butt up to the unit\'s access cover.
      Save the screws and access cover.
    • 4
      Follow the wires from the blower motor. Two wires will go to
      a capacitor located on the blower\'s housing. The rest of the wires will
      go to the control panel.
    • 5
      Cut the wires leading into the control panel with wire cutters. Leave the cut wires connected inside of the control panel.
    • 6
      Remove the retaining bolts with either a nut driver, usually
      3/8-inch, or an adjustable wrench. The retaining bolts, found on the
      mounting brackets that the blower\'s housing slides on, keep the blower\'s
      housing locked into position. Save the bolts.
    • 7
      Slide the blower motor\'s housing out of the AC unit. The housing will slide straight out along the mounting brackets.
    • 8
      Disconnect the two wires going to the capacitor. They will pull straight off the capacitor\'s terminals.
    • 9
      Unscrew the squirrel cage\'s locking-screw with an adjustable
      wrench. The squirrel cage, the bladed wheel, connects to the blower
      motor\'s shaft inside of the housing. The locking screw holds the
      squirrel cage to the shaft.
    • 10
      Unscrew the blower motor\'s mounting screws with either a nut
      driver, usually 3/8-inch, or an adjustable wrench. These screws hold
      the motor to the housing and are found on the opposite side of the
      squirrel cage, the same side that the wires leave the motor.
    • 11
      Pull the motor from the housing. A drop of oil on the shaft
      will aid in removal. If the squirrel cage sticks to the shaft, then hold
      the shaft still with an adjustable wrench while spinning the squirrel
      cage on the shaft.
    • 12
      Slide the new blower motor into the housing. The blower motor\'s shaft will slide into the squirrel cage\'s hole.
    • 13
      Tighten the blower motor\'s mounting screws.
    • 14
      Spin the blower motor\'s shaft until the flat part of the
      shaft lines up with the squirrel cage\'s locking screw. Move the squirrel
      cage in or out until it does not touch the housing or the blower motor.
      Tighten the locking screw.
    • 15
      Connect the blower motor\'s capacitor wires, usually brown or
      brown with white stripes, to the capacitor. Direct replacement motors
      use the same color-coded wires as the original.
    • 16
      Slide the blower motor\'s housing into the AC unit along the mounting brackets. Install the mounting bracket\'s retaining bolts.
    • 17
      Connect the new blower motor\'s wires in the control panel
      one at a time. Disconnect one old wire in the control panel. Determine
      its color and connect the new wire, of the same color, to its place. Do
      this for all wires.
    • 18
      Replace the control panel\'s cover, if equipped, and the
      unit\'s access cover. Turn on the power to the unit at the disconnect box
      and test the blower motor.
Jul 17, 2013 | Friedrich Kuhl Series SL28M30 230 Volt,...
Front blower switch only blows on high. How do i take apart dash to replace switch if thats what the problem is
Usually the blower motor switch is ok. The problem is more likely to be the blower motor speed resistor block which is the device which regulates how much power the switch sends to the blower motor to control it's speed. I believe that on your vehicle it located in the engine compartment at the right [passenger] side of the firewall and has a 4 or 5 wire connector plugged into it. It's a pretty common and inexpensive part so it should be readily available at most parts stores. Good luck, hope this helps!
Sep 16, 2011 | 2003 Dodge Durango
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
Where is the blower motor located on a 91 Dodge Dakota and how do I access it?
Blower Motor REMOVAL & INSTALLATION Dakota
  1. Disconnect the negative battery cable.
  2. Remove the steering column cover, intermittent wiper control and the lower instrument panel module retaining screw to the right of the steering column.
  3. Remove the center distribution duct retaining screws and panel support screw at the bottom of the module. Fig. 1: Heating/air conditioning unit components - Dakota models 88476g01.gif
  4. Remove the courtesy lamp at the lower right corner of the module and the screw near the ash receiver.
  5. Open the glovebox and remove the screws along the top edge.
  6. Move the module out and down far enough to unclip the wiring harness and antenna cable and disconnect the speaker wire (if equipped with monaural radio) and glovebox light wire. Remove the module from the vehicle.
  7. If the vehicle is equipped with air conditioning, disconnect the two vacuum lines from the recirculating air door actuator and disconnect the blower lead wires.
  8. Remove two screws at the top of the blower housing, five screws from around the housing and remove the blower housing from the unit.
  9. Remove three screw attaching the blower to the unit and remove the blower from the vehicle.
  10. Remove the fan from the blower motor.
  11. Installation is the reverse of removal. Secure all components accordingly and check the blower motor for proper operation.
Pick-Up and Ramcharger
  2. Disconnect the blower wiring. Fig. 2: Exploded view of the heater assembly components for Pick-up and Ramcharger models 88476g00.gif
  3. Remove the blower motor cooling tube. Fig. 3: Disconnect the wiring and cooling tube to access the blower motor - 1994-96 models shown 88476g06.gif
  4. Remove the screws or retaining nuts retaining the blower plate to the housing. Fig. 4: Unplug the wiring harness connector to the blower motor 88476p14.jpg
    Fig. 5: Unfasten the blower plate housing screws 88476p15.jpg
  5. Remove the assembly from the housing. Fig. 6: Lift away the blower plate housing for access to the blower motor 88476p16.jpg
  6. Remove the spring clip fastening the blower wheel to the blower shaft and pull off the wheel. Remove the blower from the plate. Fig. 7: Unclip and remove the blower wheel 88476p17.jpg
  7. Installation is the reverse of removal.
Oct 14, 2010 | 1991 Dodge Dakota
I need to know how to get to the blower fan as it is not kicking on/blowing any heat/ air and my manual does not say where it is located and how to get to it.
I will paste instruction from autozone.com below. Also, check my solution at http://www.fixya.com/cars/t6104871-heater_fan_just_quit_working_find_fuse.
  2. Remove the glove box assembly, lower right side instrument panel trim cover and right cowl trim panel, as required. Disconnect the blower lead wire connector.
  3. If the vehicle is equipped with air conditioning, disconnect the 2 vacuum lines from the recirculating door actuator and position the actuator aside.
Fig. Fig. 1: Blower motor housing cover
Fig. Fig. 2: Blower motor and wheel assembly
Fig. Fig. 3: Remove the spring-type retaining clip to separate the wheel from the blower motor
  1. Remove the 2 screws at the top of the blower housing that secure it to the unit cover.
  2. Remove the 5 screws from around the blower housing and separate the blower housing from the unit.
  3. Remove the 3 screws that secure the blower assembly to the heater or air conditioning housing and remove the assembly from the unit. Remove the fan from the blower motor by removing the spring-type retaining ring from the center of the blower wheel. Note the location of the fan-to-blower motor assembly for correct installation.
Fig. Fig. 4: To gain access to the blower motor, unplug the electrical connectors from the glove box lamp, ...
Fig. Fig. 5: ... then remove the glove box assembly from the dash panel
Sep 21, 2010 | 1989 Chrysler New Yorker
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
Where is the blower motor resister located on on a 2005 dodge dakota V6 slt?
It should be mounted on the blower box,near the blower motor to keep it cool,it mounts on the out side,but actually goes inside the blower box,it has a multi wire connector to it.
May 11, 2010 | 2005 Dodge Dakota
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
Replace heater blower motor 96 neon
With Air Conditioning
  2. Remove the right side scuff plate.
  3. Pull back the carpet from the passenger's side floor.
WARNING Be careful not to cut into the blower motor wiring!
  1. Use a suitable utility knife to cut the wheel housing silencer in line with the blower motor wiring.
  2. Detach the blower motor electrical connector.
  3. For right-hand drive vehicles, remove the motor cover.
  4. Unfasten the three blower motor retaining screws, then lower the blower motor assembly from the unit housing.
The blower motor assembly is located under the passenger's side dash panel
Blower motor mounting and location of the retaining screws and wiring-vehicles with A/C
To install:
  1. Raise the blower motor into position in the unit housing and secure with the three retaining screws.
  2. If removed, install the motor cover.
  3. Attach the blower motor electrical connector.
  4. Use tape to secure the silencer into position.
  5. Reposition the passenger's side floor carpeting.
  6. Install the right side scuff plate.
  7. Connect the negative battery cable.
Oct 25, 2009 | Chrysler Neon Cars & Trucks
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
