Question about Craftsman 1 Hp, 4 Gal. Air Compressor
A/C will only pump 30-40 lbs, but keeps running.
My 1 HP 4-gallon craftsman A/C was working just fine and then would not pump beyond 30-40 lbs. And of course it did not kick off at 110 lbs because it never gets there. I replaced the tank pressure safety valve thinking it was leaking, but nothing changed.
  • jskanzler Jun 17, 2010
    Thank you Richard152. You was right on. I made a new gasket the compressor is working fine. Cost of my fix less than $5. Thanks again.
    This was my first time with Fixya.com so I am hooked on using your web site and the next time I will join.
I have the same compressor and the exact same problem. I removed the pump head and found the gasket has blown between the two reed valve chambers in the head.
Posted on Jun 08, 2010
  • richard152 Jun 09, 2010
    Follow up......I made a new gasket from a roll of gasket material and re-installed the head. The compressor now works fine. It once again builds pressure to approximately 110psi and shuts off just as it should. I would suggest re-torquing the head after a couple of pressure/heat cycles. Hope this helps others with the same problem.
  • 59 Answers
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Posted on Jun 06, 2010
  • atthings
    atthings Jul 04, 2010
    Well you can't win them all. congratulations to Richard 152 for hitting the target!!!! I shall certainly take notice of that problem myself for future reference.
    A.
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
My Craftsman air compressor has wored fine till now. It does not want to build up pressure beyond 50 psi.yes I did check the drain valve and no leaks. Motor seems to be putting out the rpm's and the oil...
Check for a leak between you compressor head (pump) and your tank. Your pump output may be good but as your tank pressure gets higher the leak will not allow the tank to build up.
Feb 04, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
If i leave it pumping all night and the water dries up will it burn out the motor?
yes besides the water keeping the pump cool it also acts as a lubricant for pump no water can burn up and seize pump
Mar 15, 2010 | Craftsman Professional 1/4 Hp Submersible...
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 1 Hp, 4 Gal. Air Compressor Logo
576 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
