Question about Mitsubishi WD-62525 62" Rear Projection HDTV
This is a power board going to the lamp of the DLP MITSUBISHI TV I HAVE THE NEW LAMP BUT THERE NO POWER GOING TO THE LAMP THE TV HAS POWER IT WON'T LIT THE SCREEN
  • 505 Answers
There are bad capacitors on the power supply.
look for bulged caps
they look like this
replace the big ones on the power supply to fix the lamp issue
there are more bad ones inside typically on the dm and fmt boards
they are 1000uf - replace those ones with 680uf @ 16v caps
let me know if i can be of further assistance
Posted on Jun 05, 2010
Replacing uhp lamp and remove ballast with Xenon lamp and 55W ballast!
You are going to ruin the optics using a Xenon lamp. The ballast in the TV talks back via UART to the CPU. By removing the ballast the TV cannot talk to it and run itself properly. Also using a xenon lamp will give terrible color reproduction as its not putting out nearly enough lumens in the right spectrum. It will also bombard the color wheel and DLP chip with UV light and ruin those as well.
Aug 30, 2015 | Mitsubishi WD Televison & Video
Lamp Problems
If you put in an osram "neolux" type lamp--these will NOT often work in Mits. tv sets. And MIts often sends out Neolux bulbs now. A phillpis bulb for this works MUCH better.
May 02, 2014 | Mitsubishi WD-82738 model 82-Inch 3D DLP...
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV...
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Sep 13, 2010 | Mitsubishi WD-57734 57" HDTV
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns...
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
May 09, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52525 dlp capacitor problem red light after lamp chang
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dead lamp!!!
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
Jul 04, 2008 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
292 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
