Question about Samsung SW62ASP Top Load Washer
I have a samsung washer sw65asp2 faulf code 1E
Wil not commence cycle and just comes up with fault code.
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherI have a samsung washer sw65asp2 faulf code 1E - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 05, 2010
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
Error code 1E?
Hi, The IE fault code indicates that your washer is not filling properly with water
Thanks! mannu_rakesh
Aug 17, 2009 | LG WM1812C Front Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Samsung SW62ASP Top Load Washer Logo
381 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
