Question about John Deere Ar50041 Diesel Fuel Filter 3020 4030 4440 ()
How do I install fuel injectors on a 3406E Cat
  • 31 Answers
This Should be done at a dealer or by someone experianced.
There are several special instructions that have to be followed
as well as a special injector height tool required to set the injector.
Posted on Jun 13, 2010
Replaced Catalytic Conv., Fuel Pressure Reg, Fuel Pressure Sensor, Muffler/exhaust. Cat still gets glowing orange/red. Any help ?
Do a compression check of the engine. You may have a bent or burnt exhaust valve that is letting unburned fuel get into the exhaust stream. It will burn in the cat and that can cause the red glow.
Oct 28, 2015 | Cars & Trucks
I replaced catalytic converter in my 2006 Pacifica and after two months check engine light came back on,code 420 bad cat.
you will get this code when the incompletely burned fuel in the cat has built up to a certain level and cat can no longer absorb more. The cause of incompletely burned fuel in the cat can be due to many reasons:
1. sparkplugs not firing correctly (wrong gap or fouled)(problem with ingntion components(wiring to spark plugs to high resistance)
2. fuel injectors are fouled.
3. bad fuel, incorrect fuel (regular vs premium-see user manual)
You will have to verify plugs are good, plug wires are good, injectors are clean, fuel is good.
once you get these things line out the light will eventually go out.
Jan 25, 2015 | 2006 Chrysler Pacifica
I have a 1998 peterbilt 379 with cat motor its showing code 3406E with code 55 can you help me
it will be a special cat code so find a cat dealer and have it deciphered.
Jan 24, 2015 | Cars & Trucks
My check engine light is on the code catalytic efficiency 420 port 2 how do i find
the cat convertor is contaminated with fuel. If the light will not go off (its always on) you have two choices: 1. install new cat(s) or Run premium fuel until light goes out. However before doing either you must first ensure the car's: air filter is new, the spark plugs are new and you put fuel injector cleaner in every tank of fuel. and you might want to replace the O2 sensor in the exhaust pipe. (fuel injectors foul up and cause spilling of fuel instead of spraying atomized fuel and if the spark plugs are fouled they ill not do complete burn of the fuel and therefore cause fuel to get into the cat converter. The O2 sensor can also cause the computer to adjust the timing to fire the plugs and cause similar issues)
Dec 12, 2014 | 2004 Kia Sedona
I have a pete with a 3406e cat. if the jakes or out of adjustment can it drop oil pressure
highly unlikely, the jakes are just valves in the cylinders that open to let the compression escape the piston cylinder so the engine stops producing power and can slow down your engine much quicker than normal. They have nothing to do with your oil system. If you have low oil pressure my first guess would be to look at and test your oil pump.
Nov 06, 2014 | Cars & Trucks
Lpg conversion on Audi a8. 3.0l The cat has been wrecked, £2500 to replace, likely causes? The garage changed injectors 6 weeks in to reduce fuel, could that have been problem?
Yes it sure sounds like it could be.....the cat probably heated up way to much due to a bad fuel mixture
Changing injectors is never a way to go to reduce fuel flow. the injector will only spray as much fuel as the computer tells it too. The controls for the LP were probably not installed properly or not adjusted correctly.
And you may have had a marginally bad convertor to begin with before the conversion, and a bad conversion made it worse.
Feb 02, 2010 | 2005 Audi A8
John Deere Ar50041 Diesel Fuel Filter 3020 4030 4440 () Logo
1,039 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
