Question about Maytag Neptune MAH5500B Front Load Washer
Dosent squeez the water
After the cycle is done - the clothes still have water - it dosent squeezes all the water out of the clothes
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherdosent squeez the water - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 05, 2010
Dirty screen how do i clean
the best way,and easiest way to clean the screen is with: a mild soap water solutuion using a terry-cloth or cotton wash cloth.squeeze any excess water from the cloth before wiping the screen,rinse out your cloth with clean water and re-wipe the screen.
Feb 12, 2011 | Hitachi 57F500 57" Rear Projection...
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
End of cycle spin
my washer will not drain unless if the boot is squeezed.
Aug 17, 2008 | Frigidaire GLTR1670A Front Load Washer
Problems
kenmore dishwaher mod. 363.14482100 lower spray arm
wont operate on its cycle and dishes are staying soapy
after dishes done.
Aug 04, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Is it possible to remove the wringer out to clean inside it is putting out dirt onto my clothes in the wash cycle
Hi.
Your machine has a wringer? Two rollers wthat squeeze the water out as the clothes go between them? I haven't seen one of those for forty years!
Anyway, the most likely source of dirty spots is a failing bearing seal which is allowing the grease from the bearings into the washing drum. If it isn't fixed the bearings will soon fail and that will be serious :-(
If I haven't understood your problem correctly please use the "add a comment" box and tell me again. Thanks, Dicky.
Jul 12, 2008 | Maytag Washing Machines
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Clothes come out soaked
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Jun 18, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune MAH5500B Front Load Washer Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
