Question about Samsung HL-T6187S Television
DIRT ON THE INSIDE OF THE LENS - Samsung HL-T6187S Television
  • 505 Answers
Open the side access panel which is on the upper back sides of the tv. from there, you can get access to the lens. you have to pop out the plug with a flat head screwdriver to get access to the screw. let me know if you need further assistance.
Posted on Jun 05, 2010
Marks on inside of lens
If lens was cleaned properly, you may have dirt on sensor.
Feb 27, 2014 | FUJIFILM FinePix F550 EXR Digital Camera
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
Piece of dirt in the lens!
Gently tap the lens with a stick and see if the dirt will fall to the side. It may of course migrate back, but as long as it doesn't stick to the lens, it will be out of the way for most pictures when the aperture closes. If it is stuck to the lens, have it professionally cleaned, OR take consulation in the fact that closer dirt is to the "optical center" of a lens, the less effect it has on normal pictures- pictures of bright objects are different though
May 10, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Shadow on image yet nothing in front of camera. It is in the middle at the bottom edge of the image. It only appears when I set the lens so that it is all the way in at 17. I have a canon ef-s 17-55 f2.8...
Most likely it is dirt/dust on inside the lens. If it is in the bottom of the picture, the dirt will be on the top edge of the lens. If it is inside the lens, you will probably not be able to clean it your selves.
Apr 08, 2010 | Canon EOS Rebel XSi Digital Camera
Hi there. Here is what I have my KP61HS10.Every year i clean the it inside and out. Wipe down the screen and mirror lens. I notice that lens has a dirt film inside of it, I did remove it and cleaned it...
Do not attempt this. There are alighnments here that may need to be made.Just clean the dust off the lens surface. Use micro fiber towel or lense cleaning cloth.
Oct 18, 2009 | Sony KP-61HS10 61" Rear Projection...
Dirt inside back lens element
The dirt has gotten onto the front element of the rear lens group. You do not want to try partially disassembling the lens to clean it. Either Tamron or a good camera lens repair technician should be able to perform what is called a partial internal CLA (cleaning, lubrication and adjustment) of just rear portions of the lens for fairly cheap. Alternatively you may be able to pick up a used Tamron 28-200 in excellent condition for less than the repair cost of your current lens. If successful, then you could turn around and sell your 28-200 for parts or sell it to someone who knows how to service it.
Aug 10, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Dirt on the inside of the front lense
Hello, I very much doubt that a small piece of dirt on the lens is a problem. It is more likely that your sensor needs to be cleaned. Sensor dirt is more visible at small (f11 to f32) apertures. I expect that you are shooting bright snow with a small aperture & this is why you are seeing the problem. To check, try the following.
Set camera to Av, ISO 100.
take some photos of the sky, a blank wall, or some other featureless surface, as follows:
1 - Set aperture to highest possible f - number.
2 - set aperture to lowest f-number.
3 - repeat 1 with a different lens
4 - repeat 2 with a different lens.
I expect that you will see photo 1 and photo 3 will have identical smudges of dirt on them. Photos 2 and 4 should have no smudges. If this is the case, your problem is dirt on the camera sensor. The only way to fix it is to clean your sensor.
Jan 08, 2009 | Canon Cameras
Fuzzy dot
Hi
Its hard to say without seeing the camera myself, but it's either dust inside the lens or it could be a small amount of condensation that has dried up and left a small amount of dirt behind.
What you will need to do (or have somebody do) is open up the camera, tear apart the lens and see if there is any dirt on the CCD. You can also look inside the lens from the front and see if you see any dirt trapped inside.
If you see dirt trapped inside the lens.... The only solution I know of is to replace the lens. If it's on the CCD (behind the lens) it's easy to clean off. Just make sure you don't leave fingerprints on the CCD when you're cleaning it.
If you need somebody to do it for you, we are a digital camera repair business (Google Darntoothysam) and would be happy to help. I think we have a CCD cleaning listed for about $35 including return shipping of the camera, but please note as I said above if its inside the lens elements and not on the CCD we can't clean it off.
Hopefully this advice helps, and if you need to ask further questions please feel free to contact me.
Good luck from Darntoothysam com
Thomas
Sep 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
2 ISSUES: 1) Pencil tip size dot in the middle of the projection. 2) weird smell coming from projector vent.
might be a speck of dirt on your lens, possibly on the inside. I assume youe have wiped the outside of the lens? ;-) (I have to ask) If the dot seems to be following pixels exactly your projector might be broken. The smell might be from some dirt or possible an insect in the projector. Try using compressed air to blow out any dirt and dust. It might just be dirt acumulated over time that is burning to create the smell. t t might be a long shot, but if the bulb is easily removed, yo ou might try to shine a flashlight through the lens to see if there is dirt on the lens inside. If you adjust the image size mechanically, or use lens shift, does the speck move on the picture? If so, it's probably on the lens.
May 17, 2007 | InFocus ScreenPlay 5700 Multimedia...
Samsung HL-T6187S Television Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
