Question about True GDM-26 Refrigerator
Box Not cooling
I have a True GDM -23 single door frig. Here is what I know:
The compressor is working
Of the 2 lines that enter into the top coil (inside the box) the small one is getting very cold even a bit frosty. But the insulation is off in this area so im not sure that is an issue?
The fan inside the box works
Th fan below works
I have bypassed the temp control valve inside the box by linking the 2 wires that go into the back. I did this to see if it was the temp control. It did nothing to make the box cool.
Today I removed the defrost timer? Round switch about the size of a quarter in diameter and bridged these wires.
It is currently running now and I am keeping an eye on it, the compressor is ON and everything is running as it should be.
I bypassed the defrost timer thinking if this is bad it should cool right? Well Im clearly NO A/C guy so Im hoping you may suggest something else. I have a multi meeter and I am quite handy so If you could suggest systematically checking other items that would be great.
Thanks for you help
J.P.
Jumping wires out is a good way to KILL SOMEBODY!!!!! You have no idea what you are doing, PLEASE unplug it and call a refer guy.
Posted on Aug 07, 2008
How do I calibrate the temp. control on a GDM-23 that runs too cold 32-25?
If you cant get the control warm enough there are a couple of possibilities. First:You recently had gas put in the system and the system wasn't fully evacuated and a new charge weighed in. The sensor is clamped to a specific spot on the coil suction line and It is not sensing the cooling so it will run and run and run. You will need to recharge the system and the balance will be restored. The second reason is the system is losing its charge and again the temperature control is not being satisfied. You will need to find the leak, repair it and recharge the system. Temperature controls are pretty simple, are calibrated at the factory and unless abused, pretty much last the lifetime of the box. It would be easier to replace it than calibrate it. Hope this helps and good luck.
Aug 23, 2014 | True GDM-23 Refrigerator
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
Where is the thermastat on the tru slider door our pop is freezing on the left side
Most are on the top right side of the evaporator(cooling) coil inside the box.
Aug 20, 2011 | True GDM-45 Refrigerator
I have a model GDM-26. It's was blowing really cold, 30 degrees, then warm, 50 degrees, alternating between the two. Now it's not blowing cold at all and the coils on top do not get cool/cold. Both...
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Jun 29, 2011 | True GDM-26 Refrigerator
I need to replace the door bulb and the bulb above the door in my True GDM-23. What size are the bulbs and are they available in a hardware store. Thanks
The door bulb is a standard , I believe 32" t-12 newer units may be t-8, common bulb in stores. I've got an older gdm 23 and the bulb on top is a curved one , harder to find. Also these lights have ballasts that power them, they also can fail
Jun 22, 2011 | True GDM-23 Refrigerator
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
TRUE GDM 26 merchandiser has sealed lines to the freeon and cant access. The fan blows warm air and all the lights work. It just doesnt cool.The compressor was cleaned only 2Xs in 3 years.
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Apr 17, 2010 | True GDM-26 Refrigerator
True GDM-26 Refrigerator Logo
176 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
