Question about Dishwashers
Do all dishwashers use heat element or do any
Do all dishwashers use heat elements or do any connect directly to hot water?
  • 523 Answers
All dishwashers use heaters and all should be connected to hot water the heater is only to keep the water hot not to heat it
Posted on Jun 05, 2010
I don't think the water is getting as hot as it used to in my Ariston dishwasher. Our hot water heater is set high enough, but when I tried one of the dishwasher cleaners, the plug did not disolve as...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2011 | Ariston Technologies Dishwashers
Does not produce hot water.
Make sure the connections are all turned on and that their all in the right holes. It can also maybe be a problem with it's solenoid or thermostat.
Apr 18, 2011 | Dishwashers
Hot water is not hot
heatman101
Asker
Mar 16, 2011 | Dishwashers
Water not hot enough. Supply water is plenty hot but washing water is not hot.
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 12, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Oct 10, 2010 | Dishwashers
On model du81qdwgq1 is hot or cold connection
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
I want to buy a new GE diswasher but I do not know about water inlet, is it hot water or it could be normal?
Dishwashers are usually connected to the hot water line under your kitchen sink. Although, a dishwasher has a heating element of its own, connecting it to the hot water side minimizes the amount of time the heating element cycles on and reduces the amount of electricity consumed.
Feb 24, 2010 | Dishwashers
I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
F1 ERROR
This is a water heating error.
There are a few possible causes:
  1. Bad heating element
  2. Bad connection of wires to heating element
  3. Bad control board
Be sure that water hookup for dishwasher is hot water.
Unplug electrical connection to unit.
Remove front bottom cover.
Check wires to heating element for burning and that they are connected properly.
You may need a multimeter to check power to element and to help trace the circuit if necessary.
Apr 15, 2009 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
