Question about Whirlpool GU2400XTPS Built-in Dishwasher
No power loss power to dishwasher and can't get it to turn on
  • 903 Answers
Make sure the circuit breaker didn't trip. If it did, reset it. If that's not the problem, check the outlet the dishwasher connects to to make sure it's getting power.
Posted on Jun 05, 2010
I am getting error code PF on my LG LDF6810ST, what does that mean?
PF means power failure. You are having a power supply problem. Check to make sure that the plug is connected properly. Check the junction box on the lower right corner behind the kick plate to make sure the wires are connected properly. If your dishwasher is 5 years or older, remove the front door panel and check the wire harness in the door liner for any broken wires. Good luck
Jun 17, 2011 | LG LDF6810ST Stainless Steel Built-in...
My daughter loaded my dishwasher and I believe a dish was to big and stopped the washing arm to stop spinning around and now there is no power going to dishwasher.
The spray arm being blocked will not cause a loss of power.
We need a model number to determine if there are fuses in this machine or not.
Also,check the incoming power with a volt meter to make certain a house breaker is not tripped.
Mar 02, 2011 | Dishwashers
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
PF error
check for a power loss. either you haveost power to the unit or a surge on unit and resetting the breaker sometimes and cancelling out cyccle should correct if it continues then you are going to have a bad control board....good luck to you
Jan 06, 2011 | Frigidaire PLD4375RFC Dishwasher
Loss of power to the dishwasher. have changed fuse but this does not resolve. Any ideas? Thanks
must give make and model# of unit, check power,then power to unit then power going in unit at the terminal block. you will find the culprit.let me know if i was helpful.
Feb 24, 2010 | Dishwashers
Superba Dishwasher power loss
could be several things... wiring to DW might be problem, Control might be bad. Is door closing tight?
Oct 16, 2009 | Dishwashers
KitchenAid dishwasher loss of power
Electrical storms can burn out electronic components. Consider investing in whole house surge protection.
If you need assistance in selecting or installing surge protection on main power line, email me buffalonymann@yahoo.com
Jul 30, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Maytag Dishwasher not working right after storm/power loss
With the unit switched on , switch off power at the wall switch for a few minutes , this should reset the computer , if not you will need a service call.
May 03, 2017 | Maytag MDB7100AWB Dishwasher
Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Aug 12, 2006 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
101 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
