The compressor and blower doesnot turn on
I have a GSC130361DF compressor, the compressor and blower are not turn on
    Scholar:
  • 45 Answers
Turn off the electical power to the outdoor unit.. Take off the electrical panel and ther should be a round silver capacitor. If the top pushed up it is a true sign of a capacitor failure. Remove and mark the wires on the capacitor and take the capacitor to you local HVAC Wholesaler. It should cost you around 15 to 25 dollars to replace.
Posted on Jun 05, 2010
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
Goodman condenser GSC130361DF BAD BALL BEARING SOUND.
The compressor has to be replaced if the bearings are bad in the compressor. Replace the condenser fan motor if the fan motor bearings are bad.
Aug 29, 2013 | Goodman CKL42AR42 Air Conditioner
1991 chevy 1500 ac wiring diagram
Have you checked freon pressure ?
There is a clutch relay and the low pressure switch in the circuit.
There is also a master controller in the circuit that handles the compressor and blower along with the blend doors.
The wiring diagram I have is too large to post here.
Apr 20, 2013 | Cars & Trucks
When i turn my heater on (blower) my car tries to stall out. What can cause that to happen?
most likely your ac compressor is locked up. see if you can disconnect ac compressor clutch at compressor. if problem goes away, you can use heater without any problems..
Dec 15, 2012 | 2004 Dodge Stratus
Ac turns on but cold air doesnot enter cabin
does the air blower work? does the AC compressor on the engine kick on and off quickly or not at all?
Jun 06, 2010 | 2000 Chevrolet Venture
1998 olds A/C will only cool on the highway and at idle get warm? i have hooked up a gauge ti the low side and it reads about 100 psi. i have tried to add freon but it wont take. i cannot hear the clutch....
ur gass reading is good....
but on my view ur gas expires have u got reading when it pumped.after more than 2 year the gas is expires and doesnot coolling well.. as u says that at highway it cools when the engine get average race the compressor also race upon the engine and get compression right(at high speed) but at low average speed it not work because the gas doesnot compress properly due to gas expiry.....
check new gas......i think u r compressor is good enough if it cools at any time....if compressor dead then it doesnot coll at any time....because the compression valve varssuls are down at bottom......
i think my idea will healp u...good luck.
Aug 23, 2009 | Oldsmobile Aurora Cars & Trucks
Goodman condenser model GSC130361DF. compressor
That is normal too me. Just set it lower for more comfort.
Jun 28, 2009 | Heating & Cooling
Camry 1991 4 cyl.LE.Blower fan in dashboard stopped working
heater fan speed switch located in heater box by passengers feet up in heater box one plug on it cant miss two screws hold it in!!!!
Dec 27, 2008 | 1995 Toyota Camry
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
