Question about Logitech Z-5450 Computer Speakers
My z-5450 die,no any lights on my control pod,like no power
2 Suggested Answers
AldRezaine
  • 995 Answers
SOURCE: Does anyone know where I can get a replacement
Look for it to an electronics stores near you.
Posted on Mar 31, 2010
Bought ipod (white) 1 gig, from ebay .. will not play, will not start, just blinking lights. held play for 3 sec to get green light, still nothing, all controls only render orange and green blinking ......
Hi, problem can be solved. You need t look out for two things:
1. the battery of the i pod,
2. the memory of the i pod.
Checking the battery, the battery cell of the i pod might be too weak to power up the i pod, so you need to test with another battery before purchasing a new one. It may also need to be charged properly for longer hours before it can be able to power up the i pod.You can also check that out.
Checking the memory of the i pod. The memory of the i pod can also be the cause. Virus or corrupted applications can cause to malfunction.
After checking battery, if it does not work that means you will need to flash the i pod for the memory to be restore back to normal again.
Take care.
Apr 14, 2010 | Apple iPod nano
Cruise control will not engage
You will see 2 cables going to the carburetor. One will be the throttle cable and the other is the cruise. Follow the cruise cable back to the vacuum pod and you should see the vacuum lines feeding the pod. You can remove the line at the pod and place another line in that sprout and **** on the hose. If the pod contracts its good, if you **** air the pod has a hole and it is defective.
If the pod is not defective remove the vacuum line feeding the pod and check for holes.
Aug 23, 2009 | 1999 Mercury Villager
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Audio control pod seems dead
You can see about getting a new control pod from ebay or craigslist but the problem is more likely inside the subwoofer. Below I have pasted a link to a forum thread about fixing the Gigaworks S750 systems. There is not much information there about control pod problems but at least the people on the thread will help as much as they can. If you are not familiar with electronics then some of the people on the forum thread can help if you are willing to ship the subwoofer box to them.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Nov 09, 2008 | Creative Labs Gigaworks S750 Computer...
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Control pod
Double check the connections, if the connection for the control pod is good then something is wrong inside. I would say most likely thing would be a problem on the power supply inside the subwoofer box.
Nov 29, 2007 | Creative Labs Gigaworks S750 Computer...
Logitech Z-5450 Computer Speakers Logo
290 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
