PANASONIC PT-56HX41E HIT ON BUTTON AND IT CLICKS OFF, MUST UNPLUG AND REPEATS CYCLE, NEVER POWERS UP
  • 3,459 Answers
Of the power light blinks 3 times or so its a convergence failure that is shutting the TV off. Goto www.TvRepairKits.com for a kit.
Posted on Jun 06, 2010
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The tv clicks on but no picture or sound
Hi if your tv is a DLP or LCD RPTV most likely it's a ballast issue which is the board that powers the lamp.It could also be your lamp if tv is between 2-4 yrs.God bless you!
Oct 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Shuttle83
Nov 16, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Problem is double lettering PT-51HX41 51
What is the resistor location as shown on board.....for instance,
R856.......
Oct 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt-51g53w
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Sep 02, 2007 | Panasonic PT-51G53 51" Rear Projection...
Turns off 2-3 seconds after turning on-no red light?
sounds like a power deflection board issue its one board and it cost around 300 bucks its calld the d board i believe if it was just a cold joint solder it would be some xtra work trying to find the exact point but good luck
Jul 04, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
