Question about Bissell 8806 Powersteamer Upright Vacuum
The water/solution is not coming out. Why - Bissell 8806 Powersteamer Upright Vacuum
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Steam wont come out although filled with water and heated as required
If you are using tap water the holes where the water comes out are plugged. You will have to take it apart to clean. After that you should use distilled water you can purchase at your local grocery store. That is what my wife uses after I insisted.
Dec 01, 2013 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water and cleaning fluid not coming out
water head pluged use tooth brush and hot hot water ,on bottem of vacc find water heads brush until clean
May 06, 2009 | Bissell Powersteamer 1694 Upright Vacuum
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
http://www.bissell.com/
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
DIRTY WATER
remove the dirty water tank and see if the front nozzle is fitted correctly, also see if the filter is clean on the dirty water tank
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell 8806 Powersteamer Upright Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
