Question about Sharp UX CC500 Plain Paper Thermal transfer Fax
Fax not being sent clear being received very dark
What typeof alchohol should be used
    President:
  • 3,085 Answers
Buy from a Pharmacy, 99% isopropyl.
Posted on Jun 05, 2010
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
Receiving faxes with dark grey streks going down the middle of the page. Would this be a needing a drum issue
hi ;
  1. remove the cartridge and shake it ten times
  2. Clean the interior with a vacuum cleaner
  3. it can be a problem of cartridge try to use anotherr Dictionnaire - Afficher le dictionnaire
    1. verbe
      1. clean
      2. clear
      3. wash
      4. wipe
      5. clean out
      6. mop
      7. scavenge
      8. mop up
      9. swab
      10. clear away
      11. scour
      12. rub
      13. weed
      14. polish off
Aug 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i clear the fax memory? i can only send a few pages at a time without the fax not working and i think it's because the memory is full
most fax machines will show receiving memory left or transmit memory left, if it showing receiving memory full make sure there are no paper jams and there is lots of paper in paper cassettes and it will start to print all the faxes in memory... if its transmit memory, you will need to clear those documents in memory to be sent, probably waiting in que....
Dec 31, 2009 | Brother MFC-8860DN All-In-One Laser...
Says memory is low cant print how to fix
Do the following:
1. Make sure that the memory does not have any faxes in it waiting to be sent if so send them.
2. Make sure that the memory does not contain any received faxes still waiting to be printed if so print them.
3. Use the HP ToolboxFX Fax tab to perform fax tasks from the computer. The Fax tab contains links to the following main pages:
● Fax Tasks. Perform such tasks as sending a fax or clearing the fax memory.
Fax Data Properties. Manage the space used to store faxes on a computer. These settings apply only if you have chosen to send or receive faxes remotely from the computer.
Enhanced I/O
The enhanced I/O (EIO) feature allows all-in-one memory to be used for storing data received from the
host computer. When EIO is enabled, more data can be sent to the all-in-one in shorter amounts of time
so that the user can return to the software program more quickly. The
EIO feature has the followingoptions:
Auto. The all-in-one uses EIO memory allocation to increase the speed of data transfer from the host computer to the all-in-one, if necessary. The default setting is Auto.
Off. The minimum amount of all-in-one memory is used to store data that is sent from the host computer.
Page Protect. The formatter creates the entire page image in page-buffer memory before physically moving the media through the all-in-one. This process ensures that the entire page is printed.
Oct 21, 2009 | HP LaserJet 3055 All-In-One Printer
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Dark Bar only on Sent Faxes
open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Nov 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Sent fax
the question is Why can't they read it????????
compressed, dark, light.......???????????
Aug 19, 2008 | HP 1010 Plain Paper Inkjet Fax
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Fax problem
Check the slit glass for white out or other foreign debris stuck to it and clean with isopropyl alchohol. Even a small dot or even dust can cause that. the led lamp array could also have some bad sections in it so it will not distribute the light evenly on the document to be scanned. If this doesn't help post a comment and I will research further and provide more solutions.
Jan 04, 2008 | Office Equipment & Supplies
Sharp UX CC500 Plain Paper Thermal transfer Fax Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
